Originally posted by Steven Vaccaro
View Post
New item TFL Outdrive and motor assembly.
It says 42mm prop max. My twin AC Lazer 40 goes real good with the 442's(48mph). Other than that I think it would be a personal take on the scale look and size for a hull. I agree with Darin, one should grab a couple then pick out the hull. Maybe that 36" fountain P1.
It looks like a quick mod with a dremel you could accommodate a larger prop. Doesn't appear to need much to clear. I'm also wondering about the durability if you would put a 36 or 40mm can on these.HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
If i ran 2 of these on a shockwave 36 would you guys recomend a 40mm 3 blade or 2 blade prop
Thanks
Sorry guys for all the questions im kinda new to this. I kinda want a scale look not really speed, but will a set of 4 blades be to much?
I must agree that scale like boats are the way to go! I especially like boats up to about 36" long, as at my age they are easy to handle. I really must think about buying one of these drives then find a suitable hull (Challenger 31? ) This is the sort of look that I go for (jf the photo works!)Originally posted by cybercrxt View PostDefinitely Darin, I plan on giving the company feedback once I look inside them more. I want this company to have the info they need to make these units easy for their customers to use and maintain. I was already told by good friend/ boat mechanic that purchased two of these, that the grease needed to properly protect the gears, would be Lubriplate 105...and I agree with him. Its a grease/oil mix that keeps water out and will help protect the gears. I really really want to see more things like this for the hobby industry. Getting back to realistic is a must! Mike
its for 3s lipo.Originally posted by SlickZERO View PostI can't seem to find it. How many cells? What is the Kv?
http://www.offshoreelectrics.com/pro...rod=ose-B42515Steven Vaccaro
someone should try this on 4S, my old TLF outer limits is a dog on 3S barely gets on plane... If it'll run 4 i'm sold. one quick question, if I could mount around a 2000kv motor to it, would 4S be possible?
