Hmm, how big overall? Would be kind of cool to build a twin cat with these but need something with a flat transom. What size hull would you say for twins? Thanks.
Id say something in the 30" area.
a 55" would need the arrow shark gas outdrives with an electric motor.
Beautifully made! I like your shop!
Would be lovely if there is a way to make them CCW so a twin can be build with props spinning the opposite direction!
Um you could just spin the motor opposite of the other and get a L/R prop???
Not really, if they don't provide CCW flex cable, you will unravel the cable. Assuming they use cable to transfer energy from motor to prop shaft.....
I am making this a point because I want to build a twin Out Board Pursuit and i have the TFL mini OB, the problem is no one makes a custom CCW cable for that unit, it is square end 4 mm cable. I have been researching and so far no luck, therefore I am flying Multi Rotor Quads to kill my time . lol.....
I mean look,at how the engine sits on the mount at basically a 90deg angle, hard to get a flex shaft to last that sharp of an "S" bend like that. I bet it's bevel gear driven like the Arrowshark unit, just a smaller version.
