sport hydro recommendation
  • 785boats
    Wet Track Racing
    • 3423
    Originally posted by Heath M View Post
    Here's a thread with Vid Jim http://forums.offshoreelectrics.com/...Libero-Limited
    I'm starting to think 27" might be to small and I need to find a light 30" hull
    Heath.
    If you are going to stretch to 30" I think the Insane FE30 would be the one.
    You've seen how Johns' goes at lakeside. Speak to him. I'm sure he had a restricted set up in it at some stage.
    • Heath M
      • Mar 2008
      • 865
      cool thanks,do you know what he is running in restricted now?
      Brisbane,QLD, Aussie
      • 785boats
        Wet Track Racing
        • 3423
        Sorry. I don't have a clue.
        • rayzerdesigns
          • Dec 2013
          • 1228
          so you guys allow the 1800 not the 1500?? what organization is this in?? 1500 is legal in namba
          • Heath M
            • Mar 2008
            • 865
            no only the 1500, it was my bad.
            We run in the AMPBA " Australian model power boat association " but the restricted is a club class for us.
            • Heath M
              • Mar 2008
              • 865
              Here is mine, although I have a higher kv motor, it shows how well the hull handles. :-)
              http://forums.offshoreelectrics.com/...1&d=1398063425
              That goes great Tim :) I've emailed TFL twice now in the last month with no response
                Thanks, mine is not set up like TFL stock, motor is more in the front.
                I hope they're doing OK, last year when I visited the factory, the owner was very nice but did convey the difficulty of running such business in China. Did you try to e mail Monica?
                Sent from my D6708 using Tapatalk
                  One left here... http://www.hobbyking.com/hobbyking/s...or_675mm_.html
                  • Heath M
                    • Mar 2008
                    • 865
                    Thanks Ray, they have them in the aussie warehouse to but are 40 bucks more
                      These are so pretty. Mine was an used hull, however, whoever did the layout ( I got it from Ron1950 and he got it from Jim of MiniCatUSA) knew a thing or two about hydro boats. I redid the motor mount and stuffing tube but I retained the original position. I have some uncertainties with TFL's stock placement of the motor, it's rather placed towards the back. Wonder what it does to the ease of adjustment of COG?
                      Also the stock vertical fin is a rather flimsy affair. Strangely enough mine came without it and I slotted the back and put a piece of G-10 FG. I do realize the driver is not to scale but I kind of like the goofiness of the set up.
                      DSCN5108_5479.jpgDSCN5118_5483.jpgDSCN5129_5489.jpgDSCN5191_5548.jpgDSCN5201_5558.jpg
                      It would be nice if you can get a bare hull. The gel coat on mine wasn't as good as what I have come to expect from TFL, also the FG was rather frail and thin, I did two layers of FG layups, but then again, I don't know the history of the origin. I also blue printed/trued the ride pads.
                      I first ran this with Proboat's 1800kv motor, with that set up there is nothing you can do to upset the hull. When I moved to the 2100kv motor running with a detongued X642, I did feel the need to add an air dam. I use two 2s and they are placed halfway forward of the motor on each side.
                      I do apologize to have gotten carried away so much, but I love how this hydro drives and because it was an old hull, I have no worries of bashing around. lol......
                        Similar: http://www.ebay.com/itm/27-shovel-no...item1e629935bd
                        • Meniscus
                          Refuse the box exists!
                          • Jul 2008
                          • 3312
                          If you aren't dead-set on fiberglass, one of the best ones I've found in this size is the GP265 (26.5") by ML Boatworks. I have one that has performed beautifully, especially in rough conditions. It is a fairly simple build and certainly stands up to anything you could throw at it. It also survives crashes at speeds over 70 MPH if you decided to go with a different motor/setup.
                          >> Link to ML Boatworks: GP265 <<
                          GP265FE.JPG It also comes with a one-piece canopy which is better for speeds above 65 MPH or so: GP265GP.jpg
                          • wuzofoz
                            • Jan 2015
                            • 56
                            H&M do a couple in glass
                            • Heath M
                              • Mar 2008
                              • 865
                              Thanks Guys all good info.
                              I'm looking at an H+M hull at the moment :)
                                • 9481
                                [ATTACH=CONFIG]132257[/ATTACH] It also comes with a one-piece canopy which is better for speeds above 65 MPH or so: [ATTACH=CONFIG]132256[/ATTACH]
                                I've really thought about getting one of these for PSpec class
