Blue printing a cat hull
  • Gusmoyer11
    • Apr 2014
    • 171
    More pictures
      • 5660
      Nicely done, the curve in the air cuts look really great. I just watched your 50.5 mph run, super stable.
      • Gusmoyer11
        • Apr 2014
        • 171
        Its time to test more props, does any one sell them and let you try them to see if there going to work out? I know i did that with my 1978 checkmate with a 200 2.5 merc. But props for that were 350$ and up
        • Heath M
          • Mar 2008
          • 806
          We wish lol
          Brisbane,QLD, Aussie
          • Gusmoyer11
            • Apr 2014
            • 171
            #35
            https://youtu.be/PJdiqovjBRg Today with the addeed weight of the gps
              Originally posted by Gusmoyer11 View Post
              Why are you letting off? That thing is made to turn!
              • Gusmoyer11
                • Apr 2014
                • 171
                #37
                I let off so I don't have to go swim. But I have noticed it turns great about half throttle.
                I ran the boat yesterday, my temps are from 70-85 degrees and that was after several nonstop full speed straight always. Are we thinking x646?
                • madmikepags
                  • Aug 2012
                  • 1359
                  #38
                  the most important part of sanding your sponsons is making the trailing edge sharp, also i've found that when sanding the gel coat, 300-400 grit is best I've even used 200, 600 is too fine. you don't want is too smooth, you want it a little rough to break the surface tension between the water and the hull, I've seen increases in speeds of 2-3 mph with just scuffin the bottom of the boat. what prop are you running? I have swung a 648 and a 646/3 with that motor on bigger heavier hulls so you should be able to do so with a MM with no problem at all.
                  We call ourselves the "Q"
                  • madmikepags
                    • Aug 2012
                    • 1359
                    #39
                    also how deep is your rudder? a couple of inches below the prop is fine, you will pick up some speed just from shortening the rudder?
                    • Gusmoyer11
                      • Apr 2014
                      • 171
                      #40
                      Mad mike
                      What cell count were you running? The rudder is 5" total I think it the longer speed master. And I'm thinking of ordering a x645 detounged. I'm also about building a twin cheeta
                      I would be real happy at 60mph
                      • dasboata
                        • Dec 2010
                        • 3152
                        #41
                        Blocking is complete. Took almost 6 hours. Time to go run it and see what happens
                        nice job I hope it will be worth your effort I would guess that the work you did might put the bow down a bit ! I can do any prop you want I had good luck with a X445 but that is on 5S
                        • dasboata
                          • Dec 2010
                          • 3152
                          #42
                          Mike Pags is right you only need 1-1/2 - 2" of rudder below the tips of the prop
                          • Gusmoyer11
                            • Apr 2014
                            • 171
                            #43
                            I'm not totally sure it was worth any thing. Watch the videos, it ran 51.1 stock, now I'm back to 50.5. But for a few runs it was high 40s and I wasn't happy. I did close in the rear sponsons a little bit, I made them straight back and square. Before they tapered out just a hair at the transom. Maybe less drag? So I might try opening them a bit and see what it does. If nothing else this has been a learning experience.
                            • Gusmoyer11
                              • Apr 2014
                              • 171
                              #44
                              this is the last test run after all the work the last set of pads are sanded fwd to aft with 400grit wet no temps above 83 on anything after a full 5min run non stop motor was the hottest. What do people use for Greese or oil on the flex? I'm using a super lube silicone Greese water proof
                              • Gusmoyer11
                                • Apr 2014
                                • 171
                                #45
                                This was factory hull
                                51.1mph
