Blue printing a cat hull
  • Gusmoyer11
    • Apr 2014
    • 171
    To square the pads or not? Note i already did. My question is does any one else?
    The boat is a mean machine 2 carbon inlay, 1515 2200 castle 4s2p running 50.9 since pad work. It ran 51.1 the day before skuffing and squaring.
    I do
    • Gusmoyer11
      • Apr 2014
      • 171
      Before
      After
        [ATTACH=CONFIG]130049[/ATTACH]
        If your thinking that it slowed you down, I doubt it unless you messed something up. Your only .2mph off. That can be from a different amount of grease on your flex. Too many variables from day to day. Your lipos could have been 10 degrees cooler on the second day. Etc
        • Gusmoyer11
          • Apr 2014
          • 171
          Once i got home i went ahead and greesed the shaft and lubed the motor bearings. We will see what happens. The boat rides like its on rails
          • Gusmoyer11
            • Apr 2014
            • 171
            Do lipos temp really make a difference? If so can i warm them up to get more juice?
            • Flying Scotsman
              Fast Electric Adict!
              • 5195
              Yes, low battery temperature on any battery will reduce output amperage...that is less than 25C..... at freezing or below you can loose up to 50% of capacity.....up to 45C you will gain about 10%
              Douggie
              • Gusmoyer11
                • Apr 2014
                • 171
                The packs are 65c 5000 mah 4s
                • Flying Scotsman
                  • 5195
                  The "C" I was stating is celsius temperature.
                  Douggie
                  • TRUCKPULL
                    • 3293
                    You show a picture with a straight edge across the hull. What do the pads look like along each side front to back??
                    Check this out.
                    Larry
                    • Gusmoyer11
                      • Apr 2014
                      • 171
                      As you can see there is a slight roll off, should i fill it with marine tx and re sand? In the video he sands all three pads at the same time. I sanded each one seperate. Should the pads all be the same height? The rear set are a bit shorter then the middle set
                        The profile should be left alone as how AeroMarine had designed it, I don't have mine with me to check now, the thing to check is to place the hull on a glass top and check if the port side profile mirrors the star board side and vice versa.
                        The slight roll off is a no-no, this is like a "rocker", it will promote porpoising motion. I thought MM hulls are pretty good at not having this issue. Was this there or it happened after the sanding?
                        • Gusmoyer11
                          • Apr 2014
                          • 171
                          It had a wavy apperence at first, thats what made me want to improve it
                            I know, and also as shown by your earlier pictures that when you placed a wooden block ACROSS, the pads aren't flat. But did you change the height? I just wanted to know for my own curiosity...
                            • Gusmoyer11
                              • Apr 2014
                              • 171
                              Here are glass top pictures. I picked up white marine tx feel free to call me at 541-808-5201
