Why of why did my hydra 240 fry..??
  • SJFE
    • 4867
    #31
    SJFE: Ya know I read the manual front to back and nowhere did it talk about wire lengths or cautions on timing etc....and in order for you to be antithetic you'd have to be in the crowd that was not calling me foolish.Yet there you are standing amongst the majority
    Did you google that??? Really though I wasent trying to be an @ss( even though I tend to be one latley ). I just kind of vented my frustraition with this subject & needless dollars being sent up in smoke. I've seen it so many times now & it's never "our" fault....lol.
    Sorry if you took offence.
    Good luck with your boat man.
    Tom G
    • Flying Scotsman
      Fast Electric Adict!
      • 5195
      #32
      Originally posted by ghostofpf1 View Post
      OK..enough abuse already
      Hopefully this thread helps someone else avoid my apparent mistakes in the future.
      I know I've learned a few things .
      In retrospect I think my biggest mistake was abusing the motor and it took out the esc
      thanks for the help
      Ghost
      Ghost, unfortunately the makers of most rc products do not know the abuse we do to their products..high amps and voltage. That is why, if you are not sure of a setup, post it here and some guys with a lot of knowledge will help you. As they have learnt from the school of hard knocks.
      Douggie
      • ReddyWatts
        • 1756
        #33
        Ghost, after I said, "know the motors wattage rating". I discovered it is not easy to find this info. Hope to change that.
        ReddyWatts fleet photo
        • sjslhill
          • 1563
          #34
          LOL..wow this looks like fun.....
          You guys need 200A at 48V or something 9600 watts....woohoo, letsgo!
          After reading these forums, a better question might be....why has my 240 not fried yet. LOL
          • Flying Scotsman
            • 5195
            #35
            What is your setup and hull?
            Douggie
            • Mich. Maniac
              • 1456
              #36
              Douggie
              I think he just means thats what the title of the thread should have read.
              • MarkF
                dinogylipos.com
                • Mar 2008
                • 988
                #37
                I dont think your wire length had anything to do with it. I believe you fried your motor first which would have led your amp draw to go through the roof and that is what killed your controller.
                Mark
                • ghostofpf1
                  • 399
                  #38
                  Well after more research I think that the motor to esc wires need to be kept as short as possible or at least no longer than exists when new.
                  I have a new esc on the way and plan on doing whatever necessary to keep the motor - esc wires factory or shorter but would like to make an adapter for the batteries.I currently run 6mm bullets and 10ga wire on my batteries and the dual input wires on the esc can fit in an 8mm connector with a little finagling.My question is how critical is power input wire length?I can't imagine as critical as motor - esc wire length but how much wire between battery and esc is acceptable ?? Obviously as short as possible but with original battery leads (5") + adapter (3"- 4"??) + original esc leads (6") I will probably have close to 15".Only ~3" longer than using just original wiring but you gotta know I'm a little gunshy after this episode so any soothing confirmation that adding 3" - 4" of wire won't fry my new controller would be welcome.As well as any constructive opinions on what problems might arise with long battery - esc leads.If consensus is that I need to shorten up existing OEM wires to compensate (which I may have to do anyway to keep the wiring fairly clean in the hull ) I'm open to that as well but the adapter is almost a necessity so I can use the batteries in my helis and cars if need be without going 8mm everywhere
                  as always thanks in advance
                  Ghost
                  edit.You're right....motor died and fried the esc along with it.....totally my fault for pushing things way too hard
                  • AntronX
                    • 361
                    #39
                    15" seems to me like a bit much, but definitely shorten ESC - Motor wires. Iwould reposition the ESC closer to motor and batteries. I don't like to run adapters due to introducing more connectors to the system = more things that can fail (corrosion).
