cyberstorm spinning out
  • montymike
    • 786
    Originally posted by Luck as a Constant View Post
    Interesting you say that, as I'm trying to figure out placement of stuff inside mine....
    Sorry luck I don't build boats just buy them and install electronic in them so I can't help on building side just observed the way the drive gear was installed.
      Check bottom of the hull for hooks, or a depression near the back. If it has, it needs blueprinting.. Possibly...
      • rayzerdesigns
        • Dec 2013
        • 1228
        thanks guys..i have done the hull blue prnting..and actually shortened stinger..bigger turn fins..moved cog back and actually added a small skeg..boat was very good this past weekend at winter warmups..ended up winning p limited mono
        • montymike
          • 786
          How much did u shorten stinger? Thinking of doing to miine.
          • Make-a-Wake
            FE Rules!
            • 6057
            That's awesome!
            • montymike
              • 786
              Cool
              • rayzerdesigns
                • Dec 2013
                • 1228
                pic from last weekend
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  What motor and prop you have on your Cyber? I sure would like to see a vid of it running, I don't believe I have ever seen one running...........and running well for that matter.
                  • rayzerdesigns
                    • Dec 2013
                    • 1228
                    It's a p limited setup..aquacraft 2030 motor..I run a x445 prop for sprint racing..442 for offshore
                    • SlickZERO
                      • Dec 2013
                      • 138
                      Do you cut your props or just sharpen and balance them?
                      Dumas Air Boat OS 25 nitro, Dumas Air Boat Brushless, Midwest Lobster Boat, AQ Lucas Oil Cat, Dumas Hot Shot IV Proboat outboard, Delta Force Cyber Storm 33
                      • Heath M
                        • Mar 2008
                        • 865
                        It could also be as simple as to much steering, turn you travel % down on the transmitter.
                        Brisbane,QLD, Aussie
                        • MarkF
                          dinogylipos.com
                          • Mar 2008
                          • 988
                          I have had a few of these boats and Heath is right. You need to turn down the rudder throw. Mine spun out every time until I turned down the rudder throw. Some of the big gas boats do the same thing with too much rudder.
                          Mark
