Has anyone used this device?
  • Make-a-Wake
    FE Rules!
    • 6057
    Curious if anyone has tried this.............
    Lagi cari platform slot online yang nyaman dan lengkap? SIKOWD jadi pilihan banyak orang di 2026 karena tampilannya elegan, akses cepat, dan fiturnya mudah digunakan.
  • bozo586
    • Aug 2009
    • 344
    they work great with my boats----i used them this year on every boat i ran! didn't have any signal problems all year.
      Yup.
      I had a Traxxas Stampede that I upgraded with Novak BL motors and the servo would always glitch no matter what i did, put one of these on the Rx and it was great!
        • 9481
        Sweet!
        I'm going to pick up about 6 of these
        • flraptor07
          • Aug 2013
          • 2451
          Yup, when ever I have a glitch problem I use one of them and 99.9% of the time it cures it! At one time NitroRC was giving them away with every servo they sold, that's how I found out about them.
          • 3-UP
            • Jul 2014
            • 97
            What if you don't have a extra spot on your receiver ?
            • rickwess
              • Apr 2013
              • 777
              It works in the bind location as well. I use in in all my RCs (cars and boats). It's cheap insurance against glitches.
              I wish Steve carried them. Kintec sells them (hard to find but it's right on the home page).
                You can make them soooo easily......
                Fyi, if you use a receiver pack or an external bec, you can put it on a "y". It works the same way a cap bank does with batteries.
                • littlepooper206
                  • Jul 2014
                  • 159
                  Can you make one as well? So you have an extra capacitor and just slaughtered it onto the wires itself.
                  • littlepooper206
                    • Jul 2014
                    • 159
                    Solder
                      Yes. When I get home I'll look at one and tell you what cap to use.
                      • rickwess
                        • Apr 2013
                        • 777
                        It's only $4 at Kintec.
                        The cap is in the 3000uf range and anything over 10V. Easy to make it you have the female pins and connectors..........or butcher an existing cable.
                        • kevinpratt823
                          • Aug 2012
                          • 1462
                          I have been using them for years in many of my cars. Savox servos draw a lot of current, and Spektrum rx's are sensetive to low voltage, together this combination has become notorious for "brown outs", enough that AMain hobbies actually puts in a footnote warning on the Savox servos that suggests capacitors with this combo. It basically backs up a weaker BEC from voltage drop browning out the receiver under servo load. On my track, with very high speed/high torque Savox servos, every time I hit an "S" turn, where the steering went full left-full right, I would get a brown out and the ESC would have to reboot. The glitch buster would fix it with most, but so would a good external BEC, which I ran for higher voltage servos. I also never had the issue with nitro cars that ran a rx pack, and those had 2 of the same high speed/ high torque servos operating at once. I personally haven't had this problem in any of my boats, even the 2 with savox servos, perhaps because the use an rx pack, perhaps because the servos are slower, or maybe just not as much load, but they certainly wouldn't hurt. I have tried them in all my boats when trying to resolve reception issues, but they didn't help my particular issue. A simple "Y" harnesshttp://www.offshoreelectrics.com/pro...?prod=dh-1614f does the trick if all your rx ports are taken, like with the MR200.
                          My private off road rc track
                          • NativePaul
                            Greased Weasel
                            • 2770
                            No, I use Futaba FASST and get no glitches to bust.
                              • 7512
                              Ditto with my Tactic systems..
