Please take a look and give advice
    • 5660
    I always had cooling issue with the tiny rudder pick up on the Popeye's TFL rudder, the holes are on both sides and the profile is short, I tried to elongate them but it will break the middle partition.
    I am toying with the idea to add a prop wash pick up.
    This is a temporary trial version, just to see if it does help.
    This is a first on my boats and don't know if the position is more or less correct.
    Thanks in advance!
  • dasboata
    • Dec 2010
    • 3152
    Should be mounted at 2 PM that was the nitro rule you can open up the rudder with a jewlers round file,, if your good use a dremel PS you need to heat the joi nt more get the soilder to flow it will self level better
    • rearwheelin
      • 1941
      There is a pickup hole on bothe ruder sides that share the same pickup ?
      --Albert Einstein
      • Luck as a Constant
        Make Total Destroy
        • Mar 2014
        • 1952
        The prop wash looks rite.
        I remember having the fe version of the pb Elam and the rudder had the holes on both sides.
        Elongating the holes to the leading edge of rudder did not work? Maybe just elongate one side?
          Make Total Destroy
          • Mar 2014
          • 1952
          Obviously the best way to see if the rudder pickup is working is to run the boat without the hose connected. If it works nice you'll see a nice stream of water shooting str8 up
            • 5660
            Thanks, I can mount it on the other side!
            Yes, and the partition towards the rear is already gone, so my thinking is that no matter what I do, whether elongate the leading edge or enlarging it, if the middle is gone, would it not scoop up water properly?
            That is a good idea!
            I will be racing if I could see the water shooting up!
              • 5660
              And that is the problem, the material is all machined away and prevents a nice long scoop, hence a short scoop ( leading edge whatever you call it).
                • 7651
                I used to run my propwash pickups just inside the tip of the prop and like Chris said '2 o clock'. That is where the most water is pushed off.
                  • 5660
                  Thanks!
