Get a X648 detounge, thin and balance it, and see how that works. Did you detounge the Prather?
80+ mph 32" rivercat
Not too much. I'll post a pic of it tell me what you think.Originally posted by flraptor07 View PostGet a X648 detounge, thin and balance it, and see how that works. Did you detounge the Prather?
Here's a video.....
If you totally detounge the Prather it will take a lot of the prop walk out, and if you get the X648 do the same with it.
10-4....will do that before next run. Thanks!Originally posted by flraptor07 View PostIf you totally detounge the Prather it will take a lot of the prop walk out, and if you get the X648 do the same with it.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Wow. Very nice. Congrats man, lets see more!HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
Nicely done Travis. Kind of strange the m645 dont propwalk but the prather 230 does not much difference in them other than a slight pitch 2.8/3.0...I guess at those rpm's that little bit could make the diff....one of the reasons I go smaller props higher kv motors, no propwalk...looking forward to seeing what the detounging does...DJTunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf Dragboat
Thanks. I'm pretty stoked but I know she's got more in her. I'm really wanting to try a neu 1521 tho. I think it'll be a little fast on 6s. Here some pics of the two props. You can clearly tell the m645 is thicker too....Originally posted by olwarbirds View PostNicely done Travis. Kind of strange the m645 dont propwalk but the prather 230 does not much difference in them other than a slight pitch 2.8/3.0...I guess at those rpm's that little bit could make the diff....one of the reasons I go smaller props higher kv motors, no propwalk...looking forward to seeing what the detounging does...DJ
Thanks! I'll check into that prop. Cant hurt to try it.Originally posted by keithbradley View PostABC 1816
Congrats on 80mph!
Edit: I see the 1816 is 1.6 pitch....same as I have now. ...is it just a much better prop? Or maybe go with the 1.8 pitch version?32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
You could try both, but don't put too much thought into comparing the numbers. ABC props will typically perform (and load) to a higher degree than other brands with similar pitch and diameter numbers.
thats the info i was looking for. I'll try one..thx.Originally posted by keithbradley View PostYou could try both, but don't put too much thought into comparing the numbers. ABC props will typically perform (and load) to a higher degree than other brands with similar pitch and diameter numbers.
Anyone have a 1521 neu they wanna sell????32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
