Delta 26 atr copy test
  • Steven Vaccaro
    Administrator
    • 8934
    I ran one of those copy Delta force boats this weekend with the small outrunner motors.
    The motor was 2700kv and ran a 3s 2500 pack.
    It ran about 27mph with the outrunner but couldn't keep the motor temps below 160 degrees f. Tried a smaller prop, but the results were the same.
    I swapped a 10L 380 Feigao and ran 30mph with temps in the 110 area with a water jacket on the motor.
    Some thoughts about the hull and hardware.
    First the quality of the fiberglass on a scale of 1-10 is about a 7. A few minor imperfections, but better than some of the hulls out there.
    The motor, battery tray wooden mounts are a great idea, but only glued in. Mine broke away from the hull after the second run. This mount should be glued with some fiberglass cloth.
    The flex shaft is a .150 cable with a squared end at the prop shaft. The prop shaft is 4mm.
    The hull handles quite well and turns better than I would have thought without turn fins.
    I will try to post video in the next couple of days.
    Steven Vaccaro
  • fhhobbies
    • 44
    So you had no vibes in yours? Also what was the runtime with the 2500mah and what ESC did you use? Will be nice to see your vid!
    • fhhobbies
      • 44
      Also please let us know what prop works best, I will be running the 2618kv 380L, a little less then your 2890kv.
      • Steven Vaccaro
        Administrator
        • 8934
        The esc came with it and didnt have instructions. No cutoff on it worried me. So I never tried to push the packs near the end, so I'm not sure on runtime. I ran a stock prop, that I cut down by 2mm.
        Steven Vaccaro
        • Steven Vaccaro
          Administrator
          • 8934
          oh ya, I forgot to add no vibs. I will play more with it next week.
          Steven Vaccaro
          • Eyekandyboats
            • 1935
            those hulls are rather good.
            i know we have a couple running 1515 1D's at our pond ( the knock off deltas) and they handle just great!!
            EYEKANDYGRAPHICS
            www.rclipos.com
            • fhhobbies
              • 44
              Anyone have any idea what the run time would be with 2500mah? I am going to order some packs but I just want to make sure the 2500mah is big enough.
              Eyekandyboats, what is your full setup with speed and runtime you think?
              • fhhobbies
                • 44
                Steven, what strut type is on your version?
                • Eyekandyboats
                  • 1935
                  i don't own one. i said a couple of guys in our club have one.
                  but some setups for this boat. is a NEU 1515 1D (4100KV) on hydra 240 running 4500 30C 2s setup in 2P at 9000 Mah, we can run a race course ( about 1 min 30 seconds) and we can usually do two runs with out a top off.
                  EYEKANDYGRAPHICS
                  www.rclipos.com
                  • fhhobbies
                    • 44
                    Thats just crazy, sounds like a power hungy monster!
                    • Eyekandyboats
                      • 1935
                      fast is the only way. slow down and you lose.
                      but we race. 7 classes 3 heats a day.. 21 races a day with 3-6+ boats.
                      our P mono ( 12 cell or 4s boats) we have about 9 boats. N2 ( 6 cell or 2s) we have to many!
                      its fun but some people take it to seriously and it drains all the fun out of it !
                      EYEKANDYGRAPHICS
                      www.rclipos.com
                      • ED66677
                        • 1300
                        I have the 29" version but not ARTR, just bare hull, I confirm she handles very well even though mine is a bit heavy at 2,5kg, with a 8XL under 3S that's already fast for the beginner that I am!
                        Emmanuel
                        • fhhobbies
                          • 44
                          Steven, how does the speed of this boat compare to a stock SV?
                          • Eyekandyboats
                            • 1935
                            he said it does 27 mph box stock which is slower then the SV box stock.
                            EYEKANDYGRAPHICS
                            www.rclipos.com
                            • fhhobbies
                              • 44
                              I am asking because I don't know what the true speed of a stock SV is.
