Should I use a Cap Pack or not?
  • grsboats
    • 1011
    CKoz as others stated extracaps won't hurt your performance.I would get rid of this small capbabk and add two Rubicon caps from Ose and you will be safe.I've been using this same esc on my saw riggers with two extracaps 1500uf and haven't had any kind of issues Gill
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
    • Rumdog
      • 6667
      Most important question;l: what lipos. Exactly
      • Fella1340
        • May 2013
        • 1025
        Reading docs thread will dispel any bad thoughts your having about adding the extra caps and will give you a much better understanding of how the process works from battery to motor. It's the most I have learned about fe since I got into it. The small 4 cap bank added to the t-180 was a bandaid solution at best. Adding the additional castle caps will get the esc closer to how it should have been done in the first place. If you want to understand the "why" behind adding cap banks and the way to install them so they will work best read the thread. Ask him questions. You'll be happy you did.:-D
        • kevinpratt823
          • Aug 2012
          • 1462
          Nice cooling mod there, Gill!
          My private off road rc track
          • Rumdog
            • 6667
            It isn't a bandaid at all. I've never swelled a cap on a t-180. Not even the v1 with just the original caps. That speedo, running that motor, with a moderate prop and decent cell... Absolutely no reason for more caps. It's just extra unnecessary work.
            • CKoz
              • May 2014
              • 25
              Zippy 6s 30c 5000mah
              What my wife doesn't know won't hurt me.... yet.
              • CKoz
                • May 2014
                • 25
                wow, lotsa info.
                Thanks everyone. Ill read Docs article.
