It has to be a 2100kv motor, I would imagine a 1530/1D I've run my P-rigger on this motor in the low 70's for heat racing so on 6 cell I would imagine 100 is pretty attainable.
40,000 rpm........what's the problem
This topic is closed.
Thanks guys. And yes Phil knows. I busted up 2 hulls before he built one renforceded with carbon fiber. It also has a 2200kv 1530 motor. Here is an old video running 92 when i started to get bit by the bug hard. Its very early in the morning so video kind of sucks. http://www.youtube.com/watch?v=mvi9KIth-kgPT-45, 109mph, finally gave up after last bad crash
H&M 1/8 Miss Bud 73 mph
Chris Craft 16 mph
Oh thats just the sound barrier being broken LOL . But really its just the direct sunlight into the lens of the camera....looks like a light prizem.PT-45, 109mph, finally gave up after last bad crash
Chris Craft 16 mph
Thats what i was thinking (sound barrier lol)Originally posted by Gary View PostOh thats just the sound barrier being broken LOL . But really its just the direct sunlight into the lens of the camera....looks like a light prizem.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
What prop is on it here, I did a V series prop for my Phil Thomas that did the exact same thing when trying to get it jumped up, and I gave up. maybe I'll mess with it a little more.Originally posted by Gary View PostThanks guys. And yes Phil knows. I busted up 2 hulls before he built one renforceded with carbon fiber. It also has a 2200kv 1530 motor. Here is an old video running 92 when i started to get bit by the bug hard. Its very early in the morning so video kind of sucks. http://www.youtube.com/watch?v=mvi9KIth-kg
saw phil thomas
just wondering if you are just trying to go as fast as possible, why are you carrying 2 batteries? why not just one 6-s pack or two 3-s in series?Originally posted by Gary View PostI am not sure about the fighter cats esc's and yes could be identical to and built from Alien Systems but they sure seem to be some robust looking controllers. Worst part is for high amp where else would one buy from with out spending crazy money? T S Davis I run 2- 5000mah 6s 70-140 Thunder Power in parallel.
With a boat, excess weight doesn't matter as much as a land vehicle. Usually you'll need more weight to keep it on the water anyway. With today's motors and batteries...having enough power to propel it usually isn't a problem. Flying out the water isOriginally posted by urbs00007 View Postjust wondering if you are just trying to go as fast as possible, why are you carrying 2 batteries? why not just one 6-s pack or two 3-s in series?32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
When going straight I agree.Originally posted by kfxguy View PostWith a boat, excess weight doesn't matter as much as a land vehicle.
For a heat racer it's a delicate balance. Somewhere I did the G force math. Made a spread sheet for different weights and speeds on a 1/6 mile turn. Can't find it now. It's significant when you start hanging a 15 pound boat from a turn fin and try to change it's direction 180 degrees. You end up fiddling with it to find the sweet spot. I don't feel there is a hard rule either way. I've had success with both heavy boats and with paper light boats........until ya crash. Paper boat is less than thrilled with any impact.Noisy person
performance = weight to HP in motorsports. If the only way to keep a hull on the water is adding large amounts of weight with excess batteries you might want to see if prop. balance and some aerodynamics would go the same job? I run outboard tunnels and they are as hard as anything to keep on the water.
Just a thought.
Mic
Mic Halbrehder
IMPBA 8656
NAMBA 1414
I disagree. Excessive weight is added load on the motors and controllers. It's more about weight distribution and cg when running at high speeds and keeping the boat flying level. Rum is correct.... the extra battery weight is required to power the boat, not a necessity to keep it on the water.Originally posted by kfxguy View PostWith a boat, excess weight doesn't matter as much as a land vehicle. Usually you'll need more weight to keep it on the water anyway. With today's motors and batteries...having enough power to propel it usually isn't a problem. Flying out the water is"There's nothing else I really want to do other than get up and build boats." - Mike Fiore
Thought going straight is mainly what we were talking about? LolOriginally posted by T.S.Davis View PostWhen going straight I agree.
For a heat racer it's a delicate balance. Somewhere I did the G force math. Made a spread sheet for different weights and speeds on a 1/6 mile turn. Can't find it now. It's significant when you start hanging a 15 pound boat from a turn fin and try to change it's direction 180 degrees. You end up fiddling with it to find the sweet spot. I don't feel there is a hard rule either way. I've had success with both heavy boats and with paper light boats........until ya crash. Paper boat is less than thrilled with any impact.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
