40,000 rpm........what's the problem
This topic is closed.
    ***disclaimer*** this better not turn into an argument
    First off, I'm not sure what the big deal is about running 40k rpm on a regular basis. I see people on here just
    Get bent of of shape about it. Make remarks about it.....but I've yet to see some damage or proof that doing this is no good. I can understand if you using some El cheapo motors, yea, the rotor is going to come apart. But what about higher quality motors? I've never had a castle motor come apart. I had a reedy (cheap line of their motors) come apart. I was spinning it about 50k rpm. It was rated to run on 3s and that's what I was doing. Took it so art and saw why it came apart. Cheaply built.
    I want to hear/see some proof that running a motor at 40k rpm that's rated for a make of 60k rpm has blown up. I've seen people say that a boat is different that a land vehicle because it's direct drive. Well it is and it isnt. It's direct drive to a prop but a prop will always have some slip. Yes I understand a prop has more drag on it that a land vehicles drive line, but if you don't over prop it, what's the issue? Over propping it isn't going to cause the rotor to come apart from high rpm, is it? I would think no. I'd think it would be a different type of load on the motor. One that heats it up and over taxes it and the esc.
    My whole point is I'm tired of the scoffing, comments and negative things being said about running this rpm range. Come on people, this isn't the 90's anymore. Things have improved alot. Come a long way. Let's shed some light on this. I'd like to see some proof why you can't do it.
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    I have to give you a lot of credit for raising this issue and stating it in an honest, forthright and non-confrontational manner. It'll benefit all of us if a mature dialogue can be established to finally address this.
    I'll be the first to admit that I fall into the old fuddy-duddy category who has always kept the revs down below 35K or close to it. Even my SAW record holders don't breach that number and for sure my fleet of oval race boats go lower. It seems that only those interested in peak top speed want to go higher which is understandable and given that a well set up rig can do 40K or more might quench that thirst, there may well be ways to accomplish these goals without hazard. I do have some compelling answers based on many years doing the FE dance, but I'll sit on them to see if I can pick up some re-education as this thread develops. My ears are open
    • ManuelW
      • Oct 2010
      • 786
      Thats the sound of rpm, at idle that setup will spin over 77.000rpm, under load still over 60.000
      • Grazacind
        • 351
        Yummy
        Andrew
        Find it + Buy it + Twin it + Run it = WOOHOO
        • jcald2000
          • 786
          I wonder how efficient our props are at over 400 MPH tip speed in water?
          Also find a dyno run on an electric motor and notice how the torque curve drops like a rock at high RPM.
          • Mad Racer
            • Nov 2013
            • 140
            Very interesting topic.
            I have been told and read on this site that 35 to 40k is max for racing. I understand why and respect all the extremely knowledgeable guys in my clubs & on here . In saying that my latest race "cheap" spec motors in my 4s twin cat is pushing very close to 40K if my calculations are correct. In all honesty I'm more worried about getting run time ( 5 race laps & 2 mill laps) so some more testing is needed. If or when it turns sour it's all my own undoing & will were egg on my face
            Very interesting indeed.
              Thanks Tony. I was getting tired of people saying you can't do this you can't do that but when I ask why, I get no concrete answer or proof. I'll admit, I'm still a newb at this, but I'm no dummy when it come to mechanics, electrical, building and fabricating. ..and I'm sure I've established that with you guys. I just felt like I needed some proof in this matter that it's bad to turn 40k rpm. I don't think a burnt esc is indicative of this either....in my opinion it's excessive load that causes the smoke to escape (most of the time anyway....a bad combo and many other things can cause it too) not motor rpm. I am speaking from my experience which I'll admit is limited in the boating world, but all my setups have been running at or around 40k rpm and I've yet to have a motor failure. I had one esc fail ***but*** I think it was a combination of problems unrelated to motor rpm. I felt I over propped the boat and I feel like the esc was a bad apple. This particular esc is well known to have a high failure rate anyway. So let's get back to it. Anyone got some carnage to show as a result of running high rpm?
                I will admit when my rotor came apart in my buggy, I did get something out of it....a nice laugh. Lol. The buggy slammed on the brakes and slide to a stop. After figuring out the problem all I could do is laugh. Threw another motor in it and went back at it. Here's the carnage (understand this is an El cheapo motor)
                  Yes!! As long as you are not trying to spin a 450 prop on a Castle 1515 on 6s and run something reasonable, say a 442, 642. This all depending on the boat, setup, and how much prop in water of course. I have been running my 35" DF with 1717(1580kv) on 6s for going on three years on same everything. But I run 45-48mm props.
                  • don ferrette
                    • 1252
                    In terms of heat racing alot of the "preferred" rpm numbers come down to maximizing prop efficiency and battery consumption. As a generalization typical heat racing props are most efficient in the 25-35,000 range. As far as rpm numbers, even though motors may be "rated" for 60K it doesn't mean they will live at or near there continuosly. The only motors I'll twist the snot out of are my record trials motors but that is an entirely different scenario as those motors only spend a brief amount of time winding into the stratosphere rpm wise.
                    - IMPBA Hall of Fame -
                    - IMPBA Hydro Technical Director -
                    • Grazacind
                      • 351
                      Well mate I run a twin rigger with 2 Neu 1527 .5y on 6s. This is a saw setup only for me but the main issues I have experienced are parts being out of balance. You can get away with pretty good balance at 30k at 47k it is so so critical. I think this out of balance helps motors let go with the excessive vibration. Running high rpm is fine if you pay a lot of attention to balance of the whole driveline. Most don't so 30k is a more reliable setup. Just my thoughts anyway.
                      Andrew
                        I think that the OP has interpreted many of his "naysayers" incorrectly. Most were not implying that the motor would fail because it it spinning so fast (although some cheaper motors will lose a magnet or a bearing - it's happened to me). Running a motor at extreme rpm can shorten its life, but that's another issue. The real problem is amp draw and the ESC. A setup which runs 40,000 rpm or more (I have many SAW records set near or above that rpm) is usually a low-turn motor which can draw massive amps at lower rpm. Running at 40,000 rpm the setup may only draw 200 amps, but slow the motor down just a few thousand rpm and it can spike amps to well over 300. Get on Neu's site and play with their Advanced Motor Calc to see what can happen to amp draw if a slightly too-large prop is chosen. Try a Neu 1527/1D motor on 6S and see the difference in amp draw just by reducing the rpm from 41,000 to 38,000 - it increases from 230 amps to 320 amps. Just changing to a slightly larger prop can cause an ESC meltdown - and I have the ESCs to prove it.
                        But a quality 200 amp ESC can stand a 300+ amp load for a brief time because it is the heat which destroys controllers, not the amp draw. So making a pass or two with an extreme setup and bringing the boat in can be successful. Making ten passes will likely result in damage. But most sport boaters will not be happy with just two passes, so it is far safer for the majority to use a less extreme setup - hence the recommendations. Believe me, in the past thirty years I have seen more burnt boats from guys running too high of a Kv motor for their setup than from about any other cause.
                        It is certainly possible to safely sport run at 40,000 rpm, but not that many do so successfully. Too many boaters (particularly newbies) seem to believe that the only way to go fast is to turn 40,000+ rpm because they read about it somewhere. Not true, I ran almost 90 mph last year in LA turning under 35,000. Going fast isn't all about high rpm, it's about putting together a system to reach your target speed. There are various ways to get there, some carry more risk than others.
                        • flraptor07
                          • Aug 2013
                          • 2451
                          Deffinetly! Vibration plays a huge part in motor reliability, espcially harmonic vibration. It causes things like shaft flex and that in turn causes rotor failure along with centrifical force. In the last 5 to 10 years epoxies, adhesives and manufacturing processes have come a long way and that's why we don't see the failures in quality motors that we used to. Ok there's my 2 cents on the subject
                            Your right, may have interpreted incorrectly...but....I was automatically taking into consideration that the prop is matched for the setup...why would high rpm cause it to fail? Maybe we should say that past 35krpm you need to make sure everything you can balance, is balanced. I started balance my collets/couplers and I feel that goes a long way to help things last
                            • BHChieftain
                              Fast Electric Addict
                              • 2051
                              I take the practical view of running spinning things as low as RPM as possible to get the job done. I do it for my boats and my helicopters. I try to run the biggest prop I have in my box at the lowest RPM to get the output I want with correct handing characteristics. So far I have not needed more than 32K RPM (that's a 29" mono) to make the boat go faster given my power system and available props. Most of my boats are under 30K. Less RPM= less vibration issues (unless you *really* have a perfectly balanced driveline-- hard to achieve), less wear on strut and bearings.
                              If I were trying to build a boat for pure speed and ran out of prop, sure I'd think about cranking up the RPMs, but I would make that the last variable to change.
                              I guess I'd turn the question around and ask if there is any benefit on targeting a higher RPM than needed to achieve the speed target? If there were some benefit, then we could start looking at the vibration/wear factors more closely to realize that benefit. If there are no other options to hit the speed target than to increase RPM then we are back to my first point... now you are very likely trading reliability for speed which may be the tradeoff you want to make.
                              Chief
