How much salt............
  • don ferrette
    • 1252
    ...... does one need to add to a gallon of water for properly soaking a lipo pack for disposal??
    - IMPBA Hall of Fame -
    - IMPBA Hydro Technical Director -
  • Doug Smock
    • 5359
    1/2 cup/gal.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • NativePaul
      Greased Weasel
      • 2770
      I have been told to saturate the water with salt, so you cant technically put too much in, if you do the water will saturate and you will have some salt at the bottom of your salt water, if you want to avoid wastage the saturation point of salt and water varies between 36.6grams of salt per litre at 0C and 39g/L at boiling point, I normally mix it hot, as hot water absorbs the salt easier which means a lot less effort stirring. Maybe for a gallon you would have to do it cold as trying to heat it would be a PITA, but that is a LOT of dead LiPos if you need that much.
      • don ferrette
        • 1252
        I just need to lay one pack to rest.
        • Rocstar
          Joel Mertz
          • 1536
          I just pour a cup in a bucket with enough water to cover the leads and check the voltage a week later. Have one soaking now.
          • properchopper
            rcgoatbuild@snotmail.com
            • 7708
            Any friends with salt-water aquariums ?
            • Chilli
              • 3204
              There was an article that was published in the Roostertail a year or so ago on safe disposal of Lipo's. I believe it was based on Thunderpower's recommendations. It called for a cup of salt to bucket of water (a gallon or two).
              Mike Chirillo
              www.capitolrcmodelboats.com
              • electric
                • 1973
                Yes, I just disposed of a bunch of them. I just buy one cheap brand big salt container (the round one) and dump it in a bucket of water stir it up and put them in. What is that grey color residue that comes up after a day or so? Not too pretty looking water when you are done.
                  Do you need to cut the wrap open on each individual cell?
                  I too want to get rid of some old ones but wasn't sure about this procedure, remembering reading somewhere the wrapper must be cut open.
                  • martin
                    • 2881
                    You don't need to open the pack up or any thing like that, simply put the pack into the bucket of salt water.
                      Thanks!!
                        All the salt does is make the water conductive. This slowly shorts out the cells without the chance of heat, fire etc. Saturation (about 3 pounds per gallon) is neither required nor desired.
                        • kenrid
                          Fast Electric Enthusiast
                          • Dec 2012
                          • 33
                          [QUOTE=Fluid;558812]All the salt does is make the water conductive. This slowly shorts out the cells without the chance of heat, fire etc. Saturation (about 3 pounds per gallon) is neither required nor desired.
                          I thought it was desirable to fully discharge (via charger and 12 volt auto globe) the packs before immersion, (to avoid any flare ups in the bucket? or problems with the garbage truck?) which is what I did with my last 5 packs. http://forums.offshoreelectrics.com/...s/set1/sad.gif
                          FE30, Kintec Pursuit, Revolt 30, ML GP400 V2, Blackjack 29 (RIP), HK Outer Limits
                          • Rocstar
                            Joel Mertz
                            • 1536
                            This isn't rocket science, the batteries just need to be fully discharged before disposal. You can toss a fully charged pack in a bucket of salt water. If I have a bad pack, I'm not putting it on the charger for any reason. Like Jay said, the salt just makes the water more conductive. Check the voltage, if they are at zero, toss them out. If not let them soak a little longer.
                            • gsbuickman
                              • Jul 2011
                              • 1500
                              Thanks for the tip guys
                              Kinda like a revamped version of when we used lightbulb harness's to completely discharge nicd packs back in the day.
