So I did some searching. Didn't come up with much. I was thinking about putting an air dam on my cheetah. Why? I HATE blow overs and if this will help. ... I'm all for it. I havent had one yet as I just got this thing in the water. .... but it's coming once I get this thing lined out. What my question is. .. has anyone done this on a cheetah and what was the outcome? How far back in the tunnel should I put it? I already got a short length of wiper blade and attached double sided tape to it. Thanks
air dam???
All I can say is we do put air dams on some hydro's and the affect of it is usually quite stunning in a good way. Really kills the lift. The easy way to do it without over committing is to tape a piece of water line tubing a few inches back on the hull and run the boat. The affect is it disrupts the air flow and kills the lift the hydro is generating. Really will make a huge difference. On a Cat, I have no idea what the effect is(if any), but you could tape a piece of tubing under there and see what happens. If it does nothing, just pull it off.Last edited by electric; 02-21-2014, 08:32 PM.
Use a wind shield wiper, 1 inch from the front on the bottom and also some blokes in germany are using them 1 inch from both the bottom and top. The attached picture isnt mine, just one I saved as I am currently building mine
Thanks. Does it help yours or have you run it yet? Correct me if I'm wrong but yours in that pic looks further back than an inch?Originally posted by mekzoid View PostUse a wind shield wiper, 1 inch from the front on the bottom and also some blokes in germany are using them 1 inch from both the bottom and top. The attached picture isnt mine, just one I saved as I am currently building mine
[ATTACH=CONFIG]112181[/ATTACH]32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
I haven't set mine up yet, Yeah I was advised an inch, but that pic looks about 2-3 inches. If I were you id just tack it in place with 2 dots of quick set. See how it goes.
I will be doing a zig zag patten the whole way on the bottom of my Cheetah, just try different things out.. I am trying to break the 75mph barrier so I will be trying a few different things to prove to people this can be a fast hull.
Heya Kfx :-) .
I've got an airdam on my UL-1 hydro, Electric is right, it really kills lift but it sure helps keep the nose down. I used a piece of 1/2" aluminum angle from homer depot. I cut it down to fit snug between the sponsors. I used the thin servo tape to anchor it, then used hatch tape to cover gap between hull & dam, front and rear, trimmed with an x-acto and it works great.
I just tape a large drinking straw to the bottom of my 1/10 shovelnose and that works really well. Don't need much to break up the airflow.
ChiefAttached Files
Well I tried it out today. Flipped out the water several times. It's probably how high I have my prop angled. I should have tried before and after. Maybe I'll do that next weekend.
Heres a vid
What seemed to help the most was moving the batteries up towards the front. I still need to come down a little on the prop angle.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
