air dam???
    air dam???
    So I did some searching. Didn't come up with much. I was thinking about putting an air dam on my cheetah. Why? I HATE blow overs and if this will help. ... I'm all for it. I havent had one yet as I just got this thing in the water. .... but it's coming once I get this thing lined out. What my question is. .. has anyone done this on a cheetah and what was the outcome? How far back in the tunnel should I put it? I already got a short length of wiper blade and attached double sided tape to it. Thanks
    No one?
    • monojeff
      • Nov 2010
      • 2728
      Tony posted a picture if what he has on his.
      Look at his posts and you'll find it.
      OSE GIFTING ELF
      HAPPY HOLIDAYS!!
      • electric
        • 1973
        All I can say is we do put air dams on some hydro's and the affect of it is usually quite stunning in a good way. Really kills the lift. The easy way to do it without over committing is to tape a piece of water line tubing a few inches back on the hull and run the boat. The affect is it disrupts the air flow and kills the lift the hydro is generating. Really will make a huge difference. On a Cat, I have no idea what the effect is(if any), but you could tape a piece of tubing under there and see what happens. If it does nothing, just pull it off.
          Thanks. im still searching for it at the moment.
            Didnt find anything.
            • monojeff
              • Nov 2010
              • 2728
              Message tony he will post up a picture I'm sure.
              OSE GIFTING ELF
              HAPPY HOLIDAYS!!
              • mekzoid
                • Nov 2011
                • 120
                Use a wind shield wiper, 1 inch from the front on the bottom and also some blokes in germany are using them 1 inch from both the bottom and top. The attached picture isnt mine, just one I saved as I am currently building mine
                  [ATTACH=CONFIG]112181[/ATTACH]
                  Thanks. Does it help yours or have you run it yet? Correct me if I'm wrong but yours in that pic looks further back than an inch?
                  • mekzoid
                    • Nov 2011
                    • 120
                    I haven't set mine up yet, Yeah I was advised an inch, but that pic looks about 2-3 inches. If I were you id just tack it in place with 2 dots of quick set. See how it goes.
                    I will be doing a zig zag patten the whole way on the bottom of my Cheetah, just try different things out.. I am trying to break the 75mph barrier so I will be trying a few different things to prove to people this can be a fast hull.
                    • gsbuickman
                      • Jul 2011
                      • 1500
                      Heya Kfx :-) .
                      I've got an airdam on my UL-1 hydro, Electric is right, it really kills lift but it sure helps keep the nose down. I used a piece of 1/2" aluminum angle from homer depot. I cut it down to fit snug between the sponsors. I used the thin servo tape to anchor it, then used hatch tape to cover gap between hull & dam, front and rear, trimmed with an x-acto and it works great.
                        I put mine on just a few minutes ago. I already had one made up. Heres what I did
                        • BHChieftain
                          Fast Electric Addict
                          • 2051
                          I just tape a large drinking straw to the bottom of my 1/10 shovelnose and that works really well. Don't need much to break up the airflow.
                          Chief
                          • mekzoid
                            • Nov 2011
                            • 120
                            Perfect man, you even made it look good. Let us know how it goes.
                              Well I tried it out today. Flipped out the water several times. It's probably how high I have my prop angled. I should have tried before and after. Maybe I'll do that next weekend.
                              Heres a vid
                              What seemed to help the most was moving the batteries up towards the front. I still need to come down a little on the prop angle.
