lucas oil catamaran
  • Wes Rose
    • Dec 2013
    • 68
    lucas oil catamaran
    i was like a big kid when i seen the big brown truck pull in my driveway.i got my lucas oil cat today.im charging my batteries now.this is the first time ive ever had a really fast rc boat. any tips would be greatly appreciated.i do wish i could run nmih batteries in this boat.all this lipo battery stuff is blowing me away.charge amps. burst rate. parrell. different cell. different voltages.omg but im loving it. any pointers will be appreciated. thanks
  • Fella1340
    • May 2013
    • 1025
    Don't try guessing if you don't know what to.do next. if you have specific queetions ask them and somebody will be along to help. Why don't you post pictures of your new baby and introduce yourself. It helps if you list your motor size, kv, esc info and what your running for for batteries and if your running series or parallel with them. Lots of guys know way to much about this stuff and can help you set it up for best performance. You will probably get prop recommendations and strut setup advice that is best learned here for more fun on the water. Enjoy you new toy!
    • Wes Rose
      • Dec 2013
      • 68
      thanks.how do i post pics on here.
      • Wes Rose
        • Dec 2013
        • 68
        thanks for the reply.all i know is i have two 2 lipo batteries. 7.4 volts 5000 mah 2s 20 c. what does running in series or parrell mean. thanks.ps the boat has a 1800 kv brushless motor.60 amp esc
        • Wes Rose
          • Dec 2013
          • 68
          sorry.you just lost me.all i know.is i have two deans plugs in my boat and two batteries.
            You will want to run the 2s lipos in series. That means you take one positive, to the second packs negative then hook up to the speedy as a 4s pack(4s1p)or 4s 5000mah If you were to leave them parrallel you would hook both positives together and both negatives together and get the 2s pack with double the mah (2s2p) 2s 10,000 mah
            You're 'C' rating may be an issue on 4s though at only 20. That is 20 X 5 amps which is only a 100 amp discharge rate.
            Does this help explain?
            • Wes Rose
              • Dec 2013
              • 68
              lol.not really. how will it do if i just plug the batteries in and run the boat the way they are.
              • Wes Rose
                • Dec 2013
                • 68
                how will the boat do if i just plug the batteries in and run it. ps how do you put pics or videos on here
                  What is with the double posts. I did not do that. No matter.
                  You should be able to do that Wes. You figure out the pic thing yet?
                  You have to "go advanced" at bottom right beside the post reply button and follow thru.
                  • Wes Rose
                    • Dec 2013
                    • 68
                    not yet.im doing good to leave messages on here. lol if u have time could you give me a call and explain this battery thing to me. you can block your num. 864 404 0268
                    • Wes Rose
                      • Dec 2013
                      • 68
                      thanks for the help.
                      • Fella1340
                        • May 2013
                        • 1025
                        I know theres a drawing around here that makes it real simple. Simpleif you know where to look!
                          Load pictures to your pc,
                          Than in the reply box use the third icon from the right and use the box on the left to load from your pc.
                          You can load five at a time,
                          The second icon from the right is for video's from you tube url.
                          • Wes Rose
                            • Dec 2013
                            • 68
                            thanks .i did figure out the pic thing.lol i dont have a computer.i have a galaxy note 2. i do everythi.g from my phone.
                              That is ok, I am currently doing everything from the iPhone ,haha.
