Boat Slows Down As If It Reached Cell Cutoff Threshold ?
  • Cinnabun
    • Jun 2013
    • 428
    My seaking does almost the same thing but I get more than 8 seconds of burst. I reset the esc and disabled lvc and it fixed that but now after a minute the esc bugs out and starts controlling it's own throttle.
    • oscarel
      • Dec 2009
      • 2135
      If you're using the program card, 1=1(forward only) 2=1(auto calculate) or 4(4s) 3=1(no protection) 4=whatever you need to set at depending on Y or D.
      • Alexgar
        • Aug 2009
        • 3522
        Is set it to no protection just to check it you can aLways buy a Lipo sheild
          • 4297
          That sounds like you need to recalibrate the throttle range,
          You should do that first and than program the esc.
          • kendt
            • Jul 2011
            • 557
            I have two and both are problematic. I have the lvc turned off and run a separate bec and still have trouble with this.
            • Snowride
              • 297
              I swapped almost everything out. Motor, ESC, receiver, even the darn radio only to find out I have some weak batteries. Nothing else was wrong. Boat screams now but need to do something about the flex cable as I already busted one.
