Will a 7l and a x power 100 in a micro drifter be a good combo if I keep the prop on the smaller side. I've seen this set up with a navy 70 and a m535 work well with good run times? I'm planning to use 2s2p 3700 20c poly rc packs and to start with a x632 prop? Am I close for a good sport set up?
7l & x power 100
7l & x power 100
SV 27,brushless mini vee,renegade rigger,twinstorm,micro drifter,super hawaii , 1/12 miss budwieser
Tags: None
FeCalc estimates:
61 amps, 450 watts, 23750 rpm and 35 mph with the x632 prop.
72 amps, 500 watts, 23400 rpm, and 36.5 mph with the Y535 prop.ReddyWatts fleet photo
thanx
Thanx for the help with the draw and mph. I need to learn how to use that formula calc. to help with those things. Will my lipos be ok using dean connectors or do I have to upgrade? I got 4mm plugs for the esc / motor those are the right ones right?SV 27,brushless mini vee,renegade rigger,twinstorm,micro drifter,super hawaii , 1/12 miss budwieser
Yes, I have run deans on this kind of setup for years and had no problems.ReddyWatts fleet photo
