7l & x power 100
  • 62 bugzilla
    • Mar 2008
    • 341
    7l & x power 100
    Will a 7l and a x power 100 in a micro drifter be a good combo if I keep the prop on the smaller side. I've seen this set up with a navy 70 and a m535 work well with good run times? I'm planning to use 2s2p 3700 20c poly rc packs and to start with a x632 prop? Am I close for a good sport set up?
    SV 27,brushless mini vee,renegade rigger,twinstorm,micro drifter,super hawaii , 1/12 miss budwieser
  • ReddyWatts
    • 1756
    FeCalc estimates:
    61 amps, 450 watts, 23750 rpm and 35 mph with the x632 prop.
    72 amps, 500 watts, 23400 rpm, and 36.5 mph with the Y535 prop.
    ReddyWatts fleet photo
    • SJFE
      • 4867
      You shoule be fine with Reddy's suggestions. I would not pull more than 70 amps with that esc.
      • 62 bugzilla
        • Mar 2008
        • 341
        thanx
        Thanx for the help with the draw and mph. I need to learn how to use that formula calc. to help with those things. Will my lipos be ok using dean connectors or do I have to upgrade? I got 4mm plugs for the esc / motor those are the right ones right?
        • ReddyWatts
          • 1756
          Yes, I have run deans on this kind of setup for years and had no problems.
