two of these would work on this hull http://www.ebay.com/itm/Promise-Hobb...item1e710ab1c9
Stingers for 41" Sprint Cat, Buy or fabricate?
the op is. not me.HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
with this wreck that your showing. I think the hull would have ripped apart with stronger stingers. From the scratches that are on the side of your hull I think your lucky with what you have left.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
http://www.ebay.com/itm/FLEXISHAFT-S...item23112cc8cd
This one may fit. See how the top is tapered?twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
I am planning on locating the motor mounts just forward of the 2nd step. They will be 1/4 thick aluminum machined to fit the sponsons in cross section from top of tunnel down. Machine motor mounting holes then hog out the rest leaving .06 thick wall on one side. The perimeter and around motor mount holes will be full thickness. to which I will alum epoxy bond a .06 thick aluminum skin to form the hollow mount. This will be directly fed water by a pickup at the bottom and have it's own outlet at the top outside of the mount. Just holes drilled after mount is installed. No hoses needed.41" & 29" FE Aeromarine Sprint Cats, Quickdraw powered "Dollar Eater" 41" Insane Cat, 29" BL mod Graupner Cat, 24" Hydro, 29" OB Cat, BL mod NQD Tear Into Jet boat, 55" Scarab, JET SWEEP R/C pool skimmer Rescue Boat.
Yes twisted, the last one is the style needed and that I am looking for in 3/16. Running counter rotating twins. many more prop choices in 3/16 for CR than 1/4.41" & 29" FE Aeromarine Sprint Cats, Quickdraw powered "Dollar Eater" 41" Insane Cat, 29" BL mod Graupner Cat, 24" Hydro, 29" OB Cat, BL mod NQD Tear Into Jet boat, 55" Scarab, JET SWEEP R/C pool skimmer Rescue Boat.
that is true but you could turn don the shafts to 3/16 as I did.Originally posted by 78MaicoRider View PostYes twisted, the last one is the style needed and that I am looking for in 3/16. Running counter rotating twins. many more prop choices in 3/16 for CR than 1/4.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
Well when I checked fit of the stingers to transom it looked like it would be difficult to get them mounted low enough. And the mount plate would look too large and out of place. So I opted for the 3/16 version 3 with the smaller mounting area. Bonus though these are longer than the version 2.41" & 29" FE Aeromarine Sprint Cats, Quickdraw powered "Dollar Eater" 41" Insane Cat, 29" BL mod Graupner Cat, 24" Hydro, 29" OB Cat, BL mod NQD Tear Into Jet boat, 55" Scarab, JET SWEEP R/C pool skimmer Rescue Boat.
