Stingers for 41" Sprint Cat, Buy or fabricate?
  • kwiktsi
    • Sep 2008
    • 647
    Originally posted by Cooper View Post
    Not that strong. I wish I would have went with the click drives. But depends how much you are stressing them, fine for sporting but for punishment they are weak.
    Sorry to go sorta ot in this thread but I have always wondered- what the heck is a click drive and how is it different? Thanks.
    • Cooper
      • 1168
      They are a bit more stout, and a additional support can be bolted to back of transome to relocate the adjustment. Resulting in an extremely strong (crash resistant) drive. The click is just the adjustment housing small detents that click while making a small adjustment. Easy and quick to adjust. But really pricey!!
      • kwiktsi
        • Sep 2008
        • 647
        Thanks! I always hear people say "click drive" and I never knew what it meant. I will be building a twin cat one of these days, so trying to educate myself when I can :).
        • grsboats
          • 1011
          If the boat is a 41 Sprint cat these type of stingers won't work as this cat has a flat transom.If you inttend to use pre fabricated stinger this one Works in the Sprint cat http://www.horracing.com/product_inf...a0clkevcgor4.I agree with Cooper if high demand will be required in your boat! Gill
          GO FAST AND TURN RIGHT !
          www.grsboats.com.br
          • 78MaicoRider
            • Jun 2013
            • 179
            Yes I was looking at horracing stingers. (The link took me to horracing sign in page. Not sure which stinger you meant.) The 3/16 version 2 was what I was going to go with. Maybe 1/4 is needed for the abuse factor? Then reading through other boat builds, there were comments made as to setting the stingers parallel to the ride surface then pretty much leaving them. Which brought about my question. Fabricating non adjustables would be easy and worth the effort. But replicating anything like the version 2 stinger, is not worth the effort evolved. And the consensuses seems to be that the adjustment is needed.
            41" & 29" FE Aeromarine Sprint Cats, Quickdraw powered "Dollar Eater" 41" Insane Cat, 29" BL mod Graupner Cat, 24" Hydro, 29" OB Cat, BL mod NQD Tear Into Jet boat, 55" Scarab, JET SWEEP R/C pool skimmer Rescue Boat.
            • grsboats
              • 1011
              Absolutely adjustments are needed for every model.Again if your boat is a Sprintcat 41 the link i've sent show the stinger that can be used on this cat..3/16 or 1/4 will depend on motors....36 or 40 diam are ok with 3/16 flexshafts but for the 56 serie you are in the safe side with 1/4.Gill
              www.grsboats.com.br
              • 78MaicoRider
                • Jun 2013
                • 179
                Gill it is a Sprintcat 41 by Aeromarine Laminates. The link you posted doesn't seem to work for me. 3/16 version 1,2, and 3 stinger will work with a flat transom. Version 3 seems to be the weakest due to the 32mm mounting area while being the longest at 110mm. I like the 3/16 version 2 with 40mm x 47mm mounting area and adjustable length 85mm to 105mm and easy trim adjustment.
                • grsboats
                  • 1011
                  Ok the 3/16 version 2 is a good option for this boat. I used the 1/4 roller version that I modified to 3/16 teflon bushing.Gill
                  www.grsboats.com.br
                  • ls1fst98
                    • 905
                    love to see how this turns out. i have the same hull that was setup for a g23 gas. so i have all the hardware minus motor. need to figure out what to power it with a single motor.
                    • 78MaicoRider
                      • Jun 2013
                      • 179
                      My hull is straight up FE, No stringers. For single power I would use a TP Power 5692 or SSS 5694. When I started this I thought it would be less $$$ to go twins with the cost of HV >200A ESCs. I'm not sure if that is correct or not. Both paths take some dollars!!! Anyone know a good source for stingers? I was going to order from HOR Racing but $30 to ship 2 stingers, and a standard 540 motor mount seems outta hand to me. Other sites (like OSE) don't have the stinger I am looking for.
                      • Cooper
                        • 1168
                        if not ose try kintec
                        • twissted
                          • 896
                          I think I can help.
                          http://www.ebay.com/itm/108mm-adjust...item20c82a2f40
                          http://www.ebay.com/itm/108mm-adjust...item20ccb584f6
                          or if one motor you will need to set up like the HK genesis and the drive for that would be something like this
                          http://www.ebay.com/itm/Extended-80m...item20c0ffd4b4
                          I hope that I was able to under stand what your looking for?
                          http://www.ebay.com/itm/Alu-rudder-w...item20b4883161
                          The last one I've shown you is pretty sweet for money! its a 1/4 shaft so it will stand up to the big power!
                          twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
                          • ls1fst98
                            • 905
                            we can't use stingers like those on this hull since it is a flat back, has no overhang. something like a speed master strut or http://www.horracing.com/product_inf...roducts_id=621
                            that is the style the op would need. im looking for a 5692 to run in mine as a single setup just need to work out cell count and esc. sorry to get off topic or hijack
                            • twissted
                              • 896
                              More stuff to get the boat working. on the cheep.
                              http://www.ebay.com/itm/Aluminum-wat...item2572edb3c6
                              if you would rather dill hoes.
                              lhttp://www.ebay.com/itm/aluminum-dual-water-pick-up-flush-with-mount-for-rc-boat-/151068030225?pt=US_Radio_Control_Control_Line&hash =item232c5b3511
                              I buy from here when money is tight!
                              http://www.ebay.com/sch/lzrc/m.html?...p2047675.l2562
                              • ls1fst98
                                • 905
                                will aeromarine sell just a hatch for this cat? mine is all cut up for gas
