Timing timing omg
  • Zackthrills
    • Apr 2013
    • 305
    #31
    No I did not run it But for less then a micro sec just one quick pull them that was it. Why can't you make a box of water with a shaft that you can connect you motor to and you can change different props and batteries etcc and some how measure the thrust and rpms it would be under load in the water. That's what I was thinking. No I only ran that motor for less then a sec.
    • Rumdog
      • 6667
      #32
      What would be the point? There is no way of recreating the types of loads that the gear will see once actually in your boat and running.
      • Zackthrills
        • Apr 2013
        • 305
        #33
        Ok got it. Just a thought out loud
        • Livewire121
          Fast Electric Adict!!
          • 320
          #34
          Zack just use the speed calculator here on OSE. Input your data, like motor kv, cell count, prop specs, and so on. This will give you a general idea of what to expect.
          HPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
