Timing timing omg
  • Zackthrills
    • Apr 2013
    • 305
    Ya you want me to record it
    • Heaving Earth
      • 1929
      Good lord.... Why bother....
      • Heaving Earth
        • 1929
        You should hold full throttle pinned and video it, that's useful.
        • Zackthrills
          • Apr 2013
          • 305
          I'm just talking about the sound it seems allot stronger that's all
          • Heaving Earth
            • 1929
            Is it stage 3 now?
              Originally posted by Heaving Earth View Post
              Is it stage 3 now?
              If only Jay Leno can be this funny...
                I stand corrected, it is more of a David Letterman line...
                • Skullcracken
                  • 728
                  Is it stage 3 now?
                  With lots of cooling lines.
                  • Livewire121
                    Fast Electric Adict!!
                    • 320
                    HPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
                    • keithbradley
                      • 3671
                      OP:
                      Y winds are much more affected by timing changes than D winds. Don't expect to get a ton of improvement with timing changes in a D motor.
                      Also, proper timing is relative to load. Higher load: higher timing. Running your motor with no load isn't going to tell you much. Gotta put it in the water.
                      I've ran 1-16 degrees on D winds, just depends on the motor and the application. I would assume that 5 degrees should put you about where you want to be.
                      I also think that it's reasonable to argue that you could probably go faster on 5s2p (with a lower failure rate) than you will running a pair of 3s lipos.
                      www.keithbradleyboats.com
                      • Heaving Earth
                        • 1929
                        Time it to whatever you clock says. Est probly
                        • Heaving Earth
                          • 1929
                          Can't have a stage 3 without em
                          • SoFlaSpartan
                            • Mar 2013
                            • 55
                            Definitely! Im sure there are some experts on here who can tell just by the frequency that bad boy is emitting, what speeds you should expect
                            • Zackthrills
                              • Apr 2013
                              • 305
                              why don't they make a dyno for boat like they do for RC cars.that can measure thrust and RPM's or is there something already out there like that
                              • Rumdog
                                • 6667
                                There is data logging. Dude... Don't run the motor unloaded on the bench. It may already be toast at this point.
