You need to reduce the timing on that motor as its a d wind down to 3.75 degrees on a T180a esc, 15 degrees is for y wind motors.
Traxxas Spartan 67.2 mph run
Zack I use 6mm bullets on the motors and 8mm on the esc's, in my King of Shaves running 6s. You'll never have a problem with amperagewith this setup.Originally posted by Zackthrills View PostWhich size bullets do I need 6mm
RichardHPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
Spartans are so light in the front I would recommend keeping the batts forward. And I would add another set of trim tabs, lower closer to the strut. That boat cine walks a lot stock on 6s. When set up is running properly it should be a lot faster
I am not sure... look at post #111, first pic. shows Deans plug wired in series tho. Unless something is changed again. I wish he did wire it parallel, lol... which would help to explaine why the slow speed.Originally posted by SloHD View PostWell nobody has said it yet so ill say it again, when you change to bullets set it up for series. You're running parallel/3s voltage. That's why it's so slow.Too many boats, not enough time...
Doh! Didn't catch the post with pics. My apologies...Originally posted by tlandauer View PostI am not sure... look at post #111, first pic. shows Deans plug wired in series tho. Unless something is changed again. I wish he did wire it parallel, lol... which would help to explaine why the slow speed.
No problem just got my speedmaster rudder showing delivered going to work on putting it on tonight
