Traxxas Spartan 67.2 mph run
  • Zackthrills
    • Apr 2013
    • 305
    #151
    ? If I take the outer term tabs off and move them to the inner because I really only care about speed would that help. Or do I have to have all four.
    • Powerboat 5000
      • May 2013
      • 87
      #152
      I'll vid my pond tomorrow morning and post it.
      Btw the pond I'm running in is huge, so I have to hit it at around 7am to get optimal conditions.
      • Powerboat 5000
        • May 2013
        • 87
        #153
        The inners are the only thing in the water at speed. But I like having both.
        • Powerboat 5000
          • May 2013
          • 87
          #154
          I've got my inners set about 2 degrees down from 90. Strut is set at 0 running a 442 with the batts an inch off the rear. Just be careful. At that configuration, blow overs come easy. Be sure to tape up for speed runs or risk your vitals taking a bath
          • Rumdog
            • 6667
            #155
            An x645 with that setup is a bad ideas. In fact, the 2200 kv on 6s is a bad idea too. Sell the motor and buy one in the 14-1600kv range and you'll see better speeds with a good size prop.
            • Powerboat 5000
              • May 2013
              • 87
              #156
              Agreed. I would maybe run a 215 with that Leo. I'm running a 220 on a 1600 Leo and am having good results.
              • Powerboat 5000
                • May 2013
                • 87
                #157
                Two different Spartans... Not trying to confuse anyone.
                • Zackthrills
                  • Apr 2013
                  • 305
                  #158
                  That's cool. I just wish I could video myself lol and have enough room. I'm going to change my timing and get the new prop and I'm installing the speedmaster dusl pick up rudder tonight.
                  • Powerboat 5000
                    • May 2013
                    • 87
                    #159
                    Zac, did you get my pm
                    • Zackthrills
                      • Apr 2013
                      • 305
                      #160
                      yeah I did get it I'm not sure what you mean you want me to cut the speed master rudder to fit on the factory locations is that what you mean? or do you mean cut the rudder down in length?
                      • Powerboat 5000
                        • May 2013
                        • 87
                        #161
                        Not down to length... You'll see what I'm saying. If you have any questions... Just ask
                        • Speedracer128
                          • Apr 2013
                          • 288
                          #162
                          Zack,
                          Your current set up is a much faster set up than how that boat comes stock. Trouble shoot 1 thing at a time till you figure out what needs adjustment or if something is defective. That setup is fast even if I doesn't break 70.
                          For stability once you get her running you will want that other pair of tabs and batts forward. I run my boat with a couple of guys that have Spartans that are fast ranging 50's to 60's. All of them have the extra tabs, 5.5mm bullets for batts and 6mm for the motor. None of them chime walk at wot. When you get your set up working properly your boat will run faster than those Spartans, you have a bigger and higher kv motor then what they are running.
                          I did just think of something tho. If I remember correctly you reinforced your hull??? If so how much weight did you add to the hull?
                          Having too much weight with a big prop could keep a motor from getting its full rpm. Just a thought
                          • MAMBA2200
                            I need a scooby snack
                            • 1347
                            #163
                            Great speed from this boat the fastest I ever got min was 67.9mph and it took allot of trial and error don't give up
                            Sent from my FE Phone
                            • Zackthrills
                              • Apr 2013
                              • 305
                              #164
                              Ya I did add a sheet of carbon fiber I'm the rear transom. I started to do the whole hull boat speed till I got the boat right. Have everything to do the whole hull. Started it But it was not looking good so I was going to get some one to help me
                              • Speedracer128
                                • Apr 2013
                                • 288
                                #165
                                Any updates? Have you got this running rite or tried another prop?
