Help me to choose a motor for this hull
  • Alfa Spirit
    • 2183
    Hello guys,
    I found a nice Lap Cat Racing 32", I want to install an outboard motor and I'm thinking about the HOR outboard motor mount, what do you think about the scale of HOR outboard with the Lap Cat hull? Is it well made?
    It will run with 6S batteries that' s why I need a 1700kV motor that kind of tunnel hull need high RPM, do you have any idea for a motor? I would like a powerfull outrunner but I didn' t find one with this RPM
    Thanks
  • BHChieftain
    Fast Electric Addict
    • 2051
    This one is 1600kv. It is a 500 class heli motor, has a 4.98mm shaft
    Chief
    • kendt
      • Jul 2011
      • 579
      Dont use that one. I tried it on my ts3 and it wont take much prop at all. Gets hot very quickly. They seem to have over stated the wattage for that one. The prather is 2in longer than the ts3 so def not the best choice. There are lots of better ones either at HK or OSE. As fo the hor I think its too small. And likely has a 4mm shaft which is no where near enough for a 6s. I'm running the bullet drive 7.5 on mine. I wanted the 3/16 shaft, so far it seems a good match even for that size hull.
      • Alfa Spirit
        • 2183
        Well I should better forget an outrunner moor right?
        What do you think about a NEU 1515 or CC 1515 ?? 1700/1800kV ??
        • kendt
          • Jul 2011
          • 579
          I was away for the weekend hence the non response. No reason to avoid an outrunner. Just have to choose a more suitable one. The turnigy t600 would be a great out runner for that hull. I use one on my 34in kneeler and it flies. I bought another for my hot shot 45. I was tempted to try it on my ts3 but think it would be too heavy. Your hull is 2" longer and 2 1/2 " wider so it should handle the weight fine and that motor will give you tons of torque and swing a good size prop with ease.
          • Alfa Spirit
            • 2183
            @ BHChieftain I have a MMP Rapid twin setup with two Scorpion 3026 - 1400kV and 2x6S, those motors are fantastic but expensive
            I will have a look to Turnigy 600. I found a Turnigy 600 with very low kV, if you have the link, thanks
            Align 500 MX : http://www.alignrcusa.com/index.php?...dab587cb4d1998
            Keda Model KD500 : http://www.kedamodel.com/product/kd500.html
            Typhoon Brushless motor 600-32 : http://www.highendrc.com/index_eprod...products_id=53
            Leopard LC500 : http://www.leopardhobby.com/proviewe...38&gid=79&pt=3
            • Heaving Earth
              • 1929
              Castle 2028
              • iridebikes247
                • 1669
                Heaving Earth says castle 2028, I say lehner 3080
                So alfa have you run the other two boats?
                • Alfa Spirit
                  • 2183
                  I didn' t work on the boats I had other things to do. Now I have free time I will continue with the Rapid first.
                  For the Lap Cat 32 Racing I bought a Scorpion 3026 - 1900kV. This is the most powerfull 500 class heli. I found the Turnigy but shaft is 6mm and HOR motor mount work with 5mm shaft
                  • Rumdog
                    • 6667
                    http://forums.offshoreelectrics.com/...ht=#post506102
                    You mean the fountain?
                    • kendt
                      • Jul 2011
                      • 579
                      I don't think you will be happy with that motor on that hull. I've tried the 3226 1600kv on my ts3 and it wasn't nearly powerfull enough for me on that hull. Couldn't handle much prop. Your hull is even bigger and that is a smaller motor.
                      • Mattwarner
                        • Aug 2011
                        • 495
                        • Heaving Earth
                          • 1929
                          Ooooh good suggestion too -D
                          • akula
                            • Dec 2009
                            • 30
                            Two boats ???
                            No, Alfa is a hulls collector...
                            And, as usual, he asks "questions" but the answer has since bought what he wants regardless of the adviceS given to him (Scorpion 3026).
                            Do not waste your time with him, you just have to take a look on the french offshore forum to see it is on the verge of being banned.
                            He gives advice for beginners as it has never put a boat in the water, it multiplies the posts without reaching the beginning of the construction, etc...
                            HOR 32" Cat, Genesis, P1 Kos, Rapid, 47" Fountain, etc... I forget certainly many others.
                            Good luck my friends...
                            Regards,
                            Francois
                            • Alfa Spirit
                              • 2183
                              Tu n" as rien d' autre a faire ptit branleur?
                              Si tu as quelque chose a dire je t' ecoute point barre. Tu es quand meme une belle langue de pute. Il vaut mieux qu' on ne se croise pas...
                              Fais ta vie vieille mégère, tu es pourri de l' intérieur, je n' ai jamais vu ca...
                              This guy is jealous, stupid. Why do you have to talk about me? If you have something to say talk to me. Are you a man or what?
