P-Sport Hydro Setup
  • jfrancisco892
    • Feb 2012
    • 593
    P-Sport Hydro Setup
    I am going to set up my whiplash for p sport hydro and have a few things i am not quite sure about. Castle hydra ice 240, neu 1515 2D (2050kv). I am going to run 4s2p, should I get 3300mah or 4000mah? 8mm or 5.5mm bullet connectors?
  • Chilli
    • 3204
    Personally I would go with 4000mah packs if they fit. They will probably run a little cooler. 5.5 bullets are fine. Especially when running 2P.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • jfrancisco892
      • Feb 2012
      • 593
      Thanks for your input!
      • jcald2000
        • 786
        If you are going to race you will need 5000 mah cells, the are lower resistance.
        • T.S.Davis
          • 6266
          James, I ran 3300's in a 2P configuration in my P mono with a much hotter setup than we were talking about yesterday. The cells do come out pissed though. The 4000's will run cooler. Probably hold up longer too. Not sure what I'll do for P Sport yet. Not sure how to get 2 P in my existing boat. I'll have to stew on that.
          Noisy person
          • T.S.Davis
            • 6266
            I also ran Hyperian 4200's in parallel. They were much less annoyed by the abuse. Those are now entering their 4th season and turned 13.25 laps yesterday in LSO so they are holding up fine.
            Noisy person
            • jfrancisco892
              • Feb 2012
              • 593
              Just ordered some 3700s. You think 5.5s will be fine?
              • T.S.Davis
                • 6266
                Should be.
                Noisy person
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2751
                  I also ran a pair of hyperion 4200's on my PT with the Leopard. They didn't seem to mind it much.
                  I then tried running 1P and drained it down to about 15%. That pi$$ed it off quite a bit. In fact, it spent some quality time over at the PBSA (pissed battery storage area), across the road.
                    • 9481
                    I run 4000mah packs in my PMono and it runs better with the less weight and my packs still have about 35-40% left in them after 6 laps
                    using 5.5mm bullets... they run cool cuz they share the load
                    • jfrancisco892
                      • Feb 2012
                      • 593
                      Would I be able to run the H7 with this setup or m545?
                      • jfrancisco892
                        • Feb 2012
                        • 593
                        PBSA lol
                        • jfrancisco892
                          • Feb 2012
                          • 593
                          I have been debating either the neu 1515 2D 2050kv and neu 1515 1y 2200kv. Which of these is my best option?
                          • T.S.Davis
                            • 6266
                            Not sure what I'll be doing either James.
                            Noisy person
                            • jfrancisco892
                              • Feb 2012
                              • 593
                              It's such a tough decision lol
