I am going to set up my whiplash for p sport hydro and have a few things i am not quite sure about. Castle hydra ice 240, neu 1515 2D (2050kv). I am going to run 4s2p, should I get 3300mah or 4000mah? 8mm or 5.5mm bullet connectors?
P-Sport Hydro Setup
Tags: None
Personally I would go with 4000mah packs if they fit. They will probably run a little cooler. 5.5 bullets are fine. Especially when running 2P.Mike Chirillo
www.capitolrcmodelboats.com
James, I ran 3300's in a 2P configuration in my P mono with a much hotter setup than we were talking about yesterday. The cells do come out pissed though. The 4000's will run cooler. Probably hold up longer too. Not sure what I'll do for P Sport yet. Not sure how to get 2 P in my existing boat. I'll have to stew on that.Noisy person
I also ran a pair of hyperion 4200's on my PT with the Leopard. They didn't seem to mind it much.
I then tried running 1P and drained it down to about 15%. That pi$$ed it off quite a bit. In fact, it spent some quality time over at the PBSA (pissed battery storage area), across the road.
I run 4000mah packs in my PMono and it runs better with the less weight and my packs still have about 35-40% left in them after 6 lapsOriginally posted by jcald2000 View PostIf you are going to race you will need 5000 mah cells, the are lower resistance.
using 5.5mm bullets... they run cool cuz they share the load.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
PBSA lolOriginally posted by Shooter View PostI also ran a pair of hyperion 4200's on my PT with the Leopard. They didn't seem to mind it much.
I have been debating either the neu 1515 2D 2050kv and neu 1515 1y 2200kv. Which of these is my best option?Last edited by jfrancisco892; 05-22-2013, 01:40 AM.
