Traxxas Spartan about to arrive Monday morning. ..
  • TheShaughnessy
    • 1419
    #46
    Hey now those trim tabs will start working like ailerons at 60 or so mph
    • Zackthrills
      • Apr 2013
      • 305
      #47
      so then tell me where to mount them I told y'all I'm not an expert at this by any means and I'm learning. So where should a properly be mounted to
      • Zackthrills
        • Apr 2013
        • 305
        #48
        this is where I saw how to mount a turn fins and the trim tabs. http://zenoahmodifiedengines.com/rc-...uning-tips.php please explain to me how or what i did wrong and what I need to do to adjust them properly if they are mounted wrong. I send a picture of the backend of the boat so you can look at it for me. Thank you
        • MAMBA2200
          I need a scooby snack
          • 1196
          #49
          I think what their saying is there is not a need for them on a cat hull which there is not a need for either tabs or turn fins that's all
          Sent from my FE Phone
          • TheShaughnessy
            • 1419
            #50
            Turn fins and trim tabs are not hardware typically used on a cat, they are for v hulls. Only time I've heard of some one using tabs on a cat was Fluid and he was going for saw records. Think he said they didn't do much till the 80 mph mark or something like that.
            Adjustments on a cat are generally made with CG, strut height and angle.
            That being said put it in the water and see what happens. An hour in the field is worth four in a book or forum.
            • MAMBA2200
              • 1196
              #51
              Here is a video of my spartan and if i had been using better packs i would have been able to get it a little faster but this is about as good as the handling gets on a spartan
              • Speedracer128
                • Apr 2013
                • 288
                #52
                Zack,
                Might be a good idea to run that Spartan stock with 2 3's a few times before modifying it. Once that boat breaks 50 out of the box it does some serious chine walking
                If you want to check out some boats that can hit those speeds you go to fine design marine's website. The site shows the power and speeds this boats run
