Zack,
Might be a good idea to run that Spartan stock with 2 3's a few times before modifying it. Once that boat breaks 50 out of the box it does some serious chine walking
If you want to check out some boats that can hit those speeds you go to fine design marine's website. The site shows the power and speeds this boats run
Traxxas Spartan about to arrive Monday morning. ..
Turn fins and trim tabs are not hardware typically used on a cat, they are for v hulls. Only time I've heard of some one using tabs on a cat was Fluid and he was going for saw records. Think he said they didn't do much till the 80 mph mark or something like that.
Adjustments on a cat are generally made with CG, strut height and angle.
That being said put it in the water and see what happens. An hour in the field is worth four in a book or forum.
Leave a comment:
I think what their saying is there is not a need for them on a cat hull which there is not a need for either tabs or turn fins that's all
Sent from my FE Phone
Leave a comment:
this is where I saw how to mount a turn fins and the trim tabs. http://zenoahmodifiedengines.com/rc-...uning-tips.php please explain to me how or what i did wrong and what I need to do to adjust them properly if they are mounted wrong. I send a picture of the backend of the boat so you can look at it for me. Thank you
Leave a comment:
so then tell me where to mount them I told y'all I'm not an expert at this by any means and I'm learning. So where should a properly be mounted to
Leave a comment:
Hey now those trim tabs will start working like ailerons at 60 or so mph
Leave a comment:
Also your turn fins are mounted in a pointless place. instead of just bolting stuff to useless points of your boat, maybe you should research.
Happy boatingLast edited by Heaving Earth; 05-09-2013, 04:28 PM.
Leave a comment:
Turn fins are useless on a cat. Your trim tabs are mounted in the absolute wrong place and will do absolutely nothing.
Leave a comment:
I here the aquacraft minimono is pretty good thought about buying that for my boss so they don't wreck the spartan
Leave a comment:
here is a video of the boat itself and you can see the work that I've done to it. Granted it is just a toy project and it took a lot of abuse.here is the link to the YouTube video I just did forit. https://www.youtube.com/watch?v=D2X_...e_gdata_player let me know what you think.
Leave a comment:
I would like to see your MG 17 with brushless setup, I sold mine cause it was a dog even for my son. Got a Atomik Barbwire and that think rocks!!!Originally posted by Zackthrills View Postall I know is the boys had a great time doing it. I also plan on having the Geico 17 up and running within the next day or two. And will post that video and I think it will nasal lot of people how fast I got the bruhed motor boat to run with its new brushless setup.
Leave a comment:
Well zach, just have some fun for now. Don't be unrealistic about your goals. Even getting from 50mph to 60 takes some time if you want to do it without swimming after your boat all day. As far as batteries go, once you start putting bigger motors it takes more juice to run them, and running two3s packs is gonna be tough on those packs. Runtimes will be cut way down. Take some time to learn about how all this stuff works.... It doesn't happen overnight.
Glad your kids are having fun
Leave a comment:
You can run two 4s packs but it needs to be wired parallel not series like the boat is pre wired
Leave a comment:
Leave a comment:
