Lmfao!!!!
Blackjack 29...hydra200...motor suggestions on 6s
So I need some opinions on a TP Power 4082 1160kv- that's what I ended up ordering... What do you guys think? Any input?
Im just gunna start with the x642... And go from there...thanks again Jason4636 for all the help!
Thats going to be pretty slow dude. That tp power motor is very powerful especially in that hull you could prop up a lot but believe me a big low kv motor with a large prop to compensate can lead to weird handling. Small prop spinning fast works a lot better. I agree with above poster that leopard probably burnt up bc of the big prop. I've seen 2200kv 6s twin 4082s and they run fine.
That is way I like the idea of a 36mm 1400kv can in that hull,
And it will have plenty of power with out the bad handling problem to add to the mix.
Motor came In today! Tp 4082 1160kv with 8s on the x646...got 54.2mph...motor temp was about 117... battery's were 120... Esc was 105... Very tempted to run a bit bigger prop possibly x648... Still need to hook it up to the comp and see what that says...any suggestions?
I really want to see a pic of the fit under the sub-hatch of that 4082 monster. Must be extremely tight... The two 4S lipos in there is probably also a tight squeeze. Pics please!
An X648 prop is huge for this hull, dude. Could work, but pe prepared for weird handling and higher temps.
Pics coming soon! Actually I ran 2-3s on the battery trays which I customized... and a 2s up in front of the motor...actually the motor fits nice! I cut the sides on the platform where the esc and servo sits...the hull is completely reinforced with epoxy. The thing is a tank!
