Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 what outrunner should i chouse - RcBoaters Forum
  • borgie
    • Dec 2012
    • 101
    hey guys
    i was wondering what outrunner to get that would be powerful enough for a miss vegas deuce also that it could fit in my motor mount and work with the esc i have (t-180) i was looking at this one is this any good http://www.hobbyking.com/hobbyking/s...ass_Heli_.html
  • borgie
    • Dec 2012
    • 101
    sorry guys it was supposed to say chose
    and i would like to 4s
      The Turdigy motor will spin a prop. The best outrunner is the HK-3026/1900. High quality and reliability, not a cheap Chinese motor. Props to try range from an m445 to an x447.
      • borgie
        • Dec 2012
        • 101
        how bout this one http://www.hobbyking.com/hobbyking/s...er_2500KV.html
        • morewattsnow
          • Oct 2010
          • 236
          Borgie, listen to Fluid. He knows what he's talking about. A $13 dollar motor like that Hobbyking unit will buy you $13 of performance and reliability. The $78 for the Scorpion will be money well spent in the long run. Boats are HARD on electronics and quality components are a must. Buying cheap, low quality parts is the best way not to enjoy this hobby. Just my 2 cents- well, maybe a nickel because of inflation.
          Fast Electrics Have A Small Carbon Wake
          • borgie
            • Dec 2012
            • 101
            ok
            thanks for ur advice
            • borgie
              • Dec 2012
              • 101
              hello guy i,am new to outrunners will this work out fine on 5s
              http://www.hobbyking.com/hobbyking/s...Outrunner.html
              • Southwest
                • 274
                Hate to but in but 1600kv outrunner Scorp on 5S = 29600rpm. The 2010 on 5s = 37185 rpm which is to high a kv. Better off to have a low kv and a higher voltage which will run cooler and easier on esc. Just my 2 cents. Fluid is spot on with his info. I'm just an oldtimer and old school. You could run the 2010kv on 4S for a 29,000rpm. I'll let Fluid decide.
                • justski
                  • 254
                  ok still new to this why a outrunner and not just inrunner?
                  • borgie
                    • Dec 2012
                    • 101
                    fluid can u please put the link up i can't find it
                    • borgie
                      • Dec 2012
                      • 101
                      on youtube i was watching die hard rc addicts and he used this motor in the apparition http://www.hobbyking.com/hobbyking/s...Outrunner.html
                      • dogg
                        • Nov 2012
                        • 49
                        I'd like to hear Fluid's feedback on that motor as I think that although it has the right power credentials it lacks bulk required for the torque needed to push that hull without a meltdown (extreme heat and expiration of motor).
                        I am only learning as well but the outrunner I have most heard of people using is the T600 1400kva like Doby runs in his Genesis. 6s set up though from memory.
                        It's the motor I'll be looking for when I'm ready for a cheap high power upgrade, along with investigating the one listed by Fluid....
                        • borgie
                          • Dec 2012
                          • 101
                          so ur saying it won't get a hydro up on plane
                          • mtbenjamin77
                            • 885
                            If your gonna spend $80 I'd just get this. It works great in the miss vegas hull and it make the boat go as fast as the design allows. and you can get 2200kv for 4S
                            http://www.offshoreelectrics.com/pro...o-3674&cat=148
                            • borgie
                              • Dec 2012
                              • 101
                              i want to be different and use an outrunner ,dogg can you send the link to that build i can't find it
