opinions on a fast stable race cat hull
  • 41willys
    • Nov 2012
    • 51
    Ok im just new to the electric thing but have heaps of gas boats. I would like opinions on a real fast cat hull that can also corner at hi speed in race water. I had an aeromarine .45 sprint cat years ago & i must say i was impressed at how it handled. I am leaning towards another one but would like your opinion. I think i would run 4s in heat trim but also step up to 6s for a bit of saw action. I have been thinking of the 29" sprint cat again or even the AC boats lightning 28" cat but lets see what you guys think.
    Shane
    Confidence
    The feeling you get just before you say what the hell just happened
    I have owned and raced both of the cats you mentioned and the Aeromarine was the better racer. Actually I ran the MeanMachine, same bottom as the SC but a more scale deck. The Aeromarine gets pretty flighty above 100 km/h but that is too fast for such a small boat in most race water. Speeds in the mid-80s were great and can be achieved on 4S.
    • 41willys
      • Nov 2012
      • 51
      Do you think i should go to a longer hull so i can run 6s?
      Confidence
        The SprintCat 60/80 is prefect for 6S, I've been racing one for years. I use a Neu 1527/1Y but for sport use a Leopard 4092/1300 or 1350 would be perfect. That would give speeds in the high 50s/low 60s and be able to hold 6S2P easily. The 20/40 version is really too small for 6S2P and is limited once the wind or chop starts to pick up. The 60/80 version is on the upper size limit for 4S, although I've raced it on 4S with a different motort the smaller version would be more competitive for 4S racing.
        A much easier to tape up hull is the Aeromarine Team Believer with the new hatch. It also has a lot more room for access to the installation than the SprintCat. The bottom is the same as the SprintCat 60/80 and it is what I'd recommend today. For the smaller version, the MeanMachine with the new hatch has the same advantages. Steve sells the latter here.
        http://forums.offshoreelectrics.com/...light=believer
        http://www.offshoreelectrics.com/pro...prod=Aero-MM-2
