Help Needed On A Mono Setup
  • Gary Mullens
    • Sep 2009
    • 31
    I have a 26" mono I am setting up and need help on the drive setup. Below are the links I think will work on the boat. What stinger or strut setup would I need to get?
    http://www.offshoreelectrics.com/pro...?prod=ose-1075
    http://www.offshoreelectrics.com/pro...=ros-spdsd-187
    Here is the motor or one similar to it...
    http://www.hobbyking.com/hobbycity/s...hless_Inrunner
    Let me know what you think on this set up. Also, Here are the props I'm looking at.
    X435, X632 X432.
    Thanks,
    -Gary
  • dana
    • Mar 2010
    • 3660
    The cable you posted is stepped down to 1/8 propshaft. Given that a majority of props have 3/16 bore, you would need to put a sleeve on any props you use. Go with a full 3/16 shaft. Which hull is it?
    • Gary Mullens
      • Sep 2009
      • 31
      Thanks for the feedback. It's a scaled down wildthing hull that I built. The 1/8 bore props won't work?
      What about a stinger drive?
      • dana
        • Mar 2010
        • 3660
        Well are the props you mentioned 1/8 bore? You can use a stinger or a strut, up to you really.
        • dana
          • Mar 2010
          • 3660
          I'm thinking the props you mentioned might be a tad small. I run a x440/3 on my Df 26
          • Gary Mullens
            • Sep 2009
            • 31
            Thanks, I really like the idea of the stinger though. I'm fairly new to this type of setup and need some guidance on what to
            buy. I don't want to buy twice, except for breaking something. LOL
            • dana
              • Mar 2010
              • 3660
              Well you can always get the cable you posted, then just grab a 3/16 shaft cable if you choose later on. Nothing wrong with the stuff you posted
              • Gary Mullens
                • Sep 2009
                • 31
                Thanks Dana! Here is a vid with the setup I am interested in. This boat has the exact same setup.
                • dana
                  • Mar 2010
                  • 3660
                  Looks rippin man.
                  • dana
                    • Mar 2010
                    • 3660
                    the sm 3/16 adjustable stinger would be good http://kintecracing.com/Hardware.html
                    • Gary Mullens
                      • Sep 2009
                      • 31
                      I was going to ask you what you would recommend. So the components I listed will fit together with this stinger?
                      Thanks,
                      -Gary
                      • dana
                        • Mar 2010
                        • 3660
                        yes
                        • Gary Mullens
                          • Sep 2009
                          • 31
                          Which one of the Stingers should I get? The stuffing tube goes into and through the stinger?
                          • dana
                            • Mar 2010
                            • 3660
                            although, i would probably go with this bushing instead. not sure if the bushing you posted is only compatable with speedmaster stingers http://www.offshoreelectrics.com/pro...s-spds-014-bsf
                            • Gary Mullens
                              • Sep 2009
                              • 31
                              I'll be on again tomorrow, off to bed.
                              Thanks again Dana!
