Help Needed On A Mono Setup
  • BHChieftain
    Fast Electric Addict
    • 2051
    Originally posted by Gary Mullens View Post
    Which one of the Stingers should I get? The stuffing tube goes into and through the stinger?
    I have a mono with a stinger set up. I did not run the stuffing tube thru it-- the tube extends just past the transom so that it is flush with the stinger back plate when that is mounted. You can then seal the backplate to the transom to keep the water out. There should be a rubber gasket between the backplate and the stinger main tube which seals it, but allows some up/down adjustment.
    Chief
    • Gary Mullens
      • Sep 2009
      • 31
      What stinger are you running and what size?
      • Gary Mullens
        • Sep 2009
        • 31
        Originally posted by dana View Post
        although, i would probably go with this bushing instead. not sure if the bushing you posted is only compatable with speedmaster stingers http://www.offshoreelectrics.com/pro...s-spds-014-bsf
        Which one of the stingers do you recommend?
