Waxing your boats???
  • rpedro
    TEAM ATOMIK
    • 89
    I read in a blog to never wax the bottom of the boat, but they recommend using fiberglass friendly spray wax on the main body, etc... Anybody here got any advice on brands that are good for this application??? I assume a microfiber cloth will work best... Thanks all!!!
    How do you LAKE it?
  • iamandrew
    • 576
    Just Clean it with window cleaner if you want to keep it clean :)
    having said that you should probably sand it with 200Grit sand paper
    • rpedro
      TEAM ATOMIK
      • 89
      Great a comedian... You should do stand up at the Apollo... If you don't want to give decent advice... Move on... Ignore my pointless threads...
      How do you LAKE it?
      • dana
        • Mar 2010
        • 3660
        If I were to use wax, I would use mothers carnauba wax and microfiber
        • rpedro
          TEAM ATOMIK
          • 89
          Appreciate the heads up!!!
          How do you LAKE it?
          • Kenny77
            • Nov 2011
            • 60
            He wasn't joking, it's common to sand or scuff the bottoms of boats. Although I think 200 is too aggressive I use 600 on all my boats, been doing it for years.
            • rpedro
              TEAM ATOMIK
              • 89
              Sorry... Rookie here... Never heard of that... Will read more about it... Thanks!!!
              How do you LAKE it?
              • Gary
                • Jan 2009
                • 1104
                If you did some research rpedro and want a fast boat you WOULD sand the bottom of your hull. It would be a better running hull. Sanding/ squareing off all sharp corners aswell.
                H&M 1/8 Miss Bud 73 mph
                Chris Craft 16 mph
                • rpedro
                  TEAM ATOMIK
                  • 89
                  appreciate the insight... I have been trying to read all I can... RC boating is pretty new to me... thanks for the help guys!!!
                  How do you LAKE it?
                  • siberianhusky
                    • Dec 2009
                    • 2206
                    IF you decide to wax the topsides I'd do what Dana says and use a pure Carnuba wax, a lot of additives lilke silicon are almost impossible to remove from the hull and can make future repairs almost impossible to finish right unless you sand and refinish the whole boat.
                    • jcald2000
                      • 786
                      Think your hatch tape will stick to a waxed topside????
                      • Jersey Crewmax
                        • 495
                        That's interesting, I'd like to know that too.
                        • rpedro
                          TEAM ATOMIK
                          • 89
                          I was thinking the same thing... I might just leave the hull alone... wipe it down with a clean microfiber cloth...
                          How do you LAKE it?
                          • rpedro
                            TEAM ATOMIK
                            • 89
                            will keep that in mind... thanks!!!
                            How do you LAKE it?
                            • HTVboats
                              • 936
                              I have never had a problem with waxing fiberglass gel coat finishes. The mild abraisives in a cleaner wax will polish your finish a clean grease and imbedded dirt. Yes silicone can be tough for painting and repairs. All repairs should be sanded and cleaned with solvents. I have built and repaired glass and epoxy boats for 30 years and on my radio boxes I wax to clean them after using white gas or alcohol to get adhesive residue off. In my opinion the tape sticks better to a clean waxed surface. Tri it? wax comes off easily if you don't like it.
                              The old debate "polished or 320 grit finish" will go on forever. Props and running surfaces. If you want a hull thats slick just coat it with RainX. Don't plan on painting it again.
                              Mic
                              Mic Halbrehder
                              IMPBA 8656
                              NAMBA 1414
