I read in a blog to never wax the bottom of the boat, but they recommend using fiberglass friendly spray wax on the main body, etc... Anybody here got any advice on brands that are good for this application??? I assume a microfiber cloth will work best... Thanks all!!!
Waxing your boats???
Great a comedian... You should do stand up at the Apollo... If you don't want to give decent advice... Move on... Ignore my pointless threads...Originally posted by iamandrew View PostJust Clean it with window cleaner if you want to keep it clean :)
having said that you should probably sand it with 200Grit sand paperHow do you LAKE it?
He wasn't joking, it's common to sand or scuff the bottoms of boats. Although I think 200 is too aggressive I use 600 on all my boats, been doing it for years.Originally posted by rpedro View PostGreat a comedian... You should do stand up at the Apollo... If you don't want to give decent advice... Move on... Ignore my pointless threads...
Sorry... Rookie here... Never heard of that... Will read more about it... Thanks!!!Originally posted by Kenny77 View PostHe wasn't joking, it's common to sand or scuff the bottoms of boats. Although I think 200 is too aggressive I use 600 on all my boats, been doing it for years.How do you LAKE it?
If you did some research rpedro and want a fast boat you WOULD sand the bottom of your hull. It would be a better running hull. Sanding/ squareing off all sharp corners aswell.PT-45, 109mph, finally gave up after last bad crash
H&M 1/8 Miss Bud 73 mph
Chris Craft 16 mph
appreciate the insight... I have been trying to read all I can... RC boating is pretty new to me... thanks for the help guys!!!Originally posted by Gary View PostIf you did some research rpedro and want a fast boat you WOULD sand the bottom of your hull. It would be a better running hull. Sanding/ squareing off all sharp corners aswell.How do you LAKE it?
IF you decide to wax the topsides I'd do what Dana says and use a pure Carnuba wax, a lot of additives lilke silicon are almost impossible to remove from the hull and can make future repairs almost impossible to finish right unless you sand and refinish the whole boat.If my boats upside down then who owns the one I thought I was driving the last two laps?
will keep that in mind... thanks!!!Originally posted by siberianhusky View PostIF you decide to wax the topsides I'd do what Dana says and use a pure Carnuba wax, a lot of additives lilke silicon are almost impossible to remove from the hull and can make future repairs almost impossible to finish right unless you sand and refinish the whole boat.How do you LAKE it?
I have never had a problem with waxing fiberglass gel coat finishes. The mild abraisives in a cleaner wax will polish your finish a clean grease and imbedded dirt. Yes silicone can be tough for painting and repairs. All repairs should be sanded and cleaned with solvents. I have built and repaired glass and epoxy boats for 30 years and on my radio boxes I wax to clean them after using white gas or alcohol to get adhesive residue off. In my opinion the tape sticks better to a clean waxed surface. Tri it? wax comes off easily if you don't like it.
The old debate "polished or 320 grit finish" will go on forever. Props and running surfaces. If you want a hull thats slick just coat it with RainX. Don't plan on painting it again.
Mic
Mic Halbrehder
IMPBA 8656
NAMBA 1414
