Ouch! a bit more than a "small crack" ;-) I would use some marine grade epoxy with some micro ballons mixed in to thicken it a bit. Or just the epoxy itself. Looks like it hit something solid. but not too bad, very fixable. Try to search for ABS glue epoxy or glue.
New guy with a Villian IV, now a rebuild.
Is there room to adjust motors for a bigger pinion gear? I would put it all together and run it and see how you like it before you get too involved in it. Sometimes it can be cheaper to start with something fast and make it faster than to take something not so fast and try to make it fly. These were made to be a fun boat with longer run times and not HIGH speed. Speed is always directly related to $$$$ decide how fast you want to go? Not saying it WON'T go fast. Enjoy and have fun with it.Don't forget to put your brain in gear before you engage your mouth! Thanks Dad!
Well, thats a fine example of a nice Villain for sure! Get the front end fixed up first. Then simply install you r new motors as they will be a direct fit. Try it first with the stock props, you may need to upgrade to steel U joints with 8-10 times the power of stock!! Also, you will need to find some big spur gears to handle the power as the "delryn over metal" gears will give way eventually. You will also need to get different pinions as the Velineon shafts are 5mm I believe...........if I'm wrong then you are good............for a bit.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Hi Mudn_1
I have built several of the Graupner offshore style kits which have ABS hulls. They recommend a glue called Stabilit Express. It is available from specialists hobby suppliers in UK. presume that it is available in US. This will certainly fix your hull as it will stick virtually anything to ABS or fill joints. Whatever you do, don't try splitting and rejoining. It will be a total pain to try and do properly.Last edited by gb tiggycat; 07-12-2012, 04:03 PM.
I would not split it. Worst case if u find no glue for ABS plastic Home Depot or wherever and get some quality white or clear cilicone and fill the hole. When u get enough in there wet your finger and smooth it out nice.Don't forget to put your brain in gear before you engage your mouth! Thanks Dad!
I sealed it up this morning with some plasti-weld..... and this afternoon did some bathtub testing..... she floats!!! the only place I seem to get any water is through the servo arm grommet hicky's.... what do ya'll do here? marine grease? its just a bit and thats with me pushing it down in water....
also, what kind of paint is best for ABS? I have some different krylons as well as some lexan paint...
I just use the cheap "Rustoleum" type rattle can enamel paint, I've made some of my boats look pretty nice with those.
The steering boots are bound to let in a bit of water unless they are brand new, greased and supertight, remember, when you are running the boat they are not in the water. 99% of RC boats get some amount of water in them.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Thats what I figured....do you have any villian parts that might interest me, such as props, upgraded shafts, watercooling etc. that you want to part with?Originally posted by Make-a-Wake View PostI just use the cheap "Rustoleum" type rattle can enamel paint, I've made some of my boats look pretty nice with those.
I'll check in the morningNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Hey mudn, check out my for sale thread, This is one with full bearings and 3/16 stub shafts etc.................... not thinking you'r wanting it, but maybe you'd like to see some of it.
http://forums.offshoreelectrics.com/...very-very-nice!NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
that thing is sweet... but at the moment, I would like to build mine and seehow much fun I can have with a boat.... so I am looking for parts, like the props, upgraded shafts, ujoints, watercooling kit, bearings etc. from that boat if you want to part it out....you can keep the hull lol..
I've got started painting....its looking sweet so far, I'll get some pics up when I get finished... but I will be a couple of days, I dont have a water cooling kit yet, do I need to drill my holes now or is it ok when I get it? If now, what size and what location?
Here's what i have, this is barely used equipment from a nice Villain and I would need to work out some sort of fair price with you since I could easily sell this stuff on ebay, Lemme know what you need out of it, possibly all of it and we'll work something out thats very fair.Attached FilesNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
