New guy with a Villian IV, now a rebuild.
  • Make-a-Wake
    FE Rules!
    • 6057
    #31
    If you cant find the steel u-joints, then these are better than the stock ones and much quiter, made by Graupner................a boat company, as opposed to Traxxas, a Land RC company.
    http://www.funrcboats.com/ProductInf...oductid=GR3545
    There are other sizes on that site too, this one is if you want to go with 5mm drive shaft and 4mm short shaft. The 5mm is the key to accepting the Castle spur gear properly.
    I wonder how these steel ones would work from right here in OSE 4mm to 5mm too! http://www.offshoreelectrics.com/pro...?prod=cen-bj21
    • mudn_1
      • 49
      #32
      so basically from the spur gear it will be 5mm to 4mm at the joint to 3/16 at the prop? is this correct if I upgrade?
      • Make-a-Wake
        FE Rules!
        • 6057
        #33
        From the spur gear its 5mm which fits the boca bearings which fit into the end of brass tubes that are also different from the stock ones, cant remember the ID of them, but when you get the flanged bocas make sure the OD of the bearinn hub(not the flange) fits the ID if the tube. This 5mm shaft then extend out of the transom a small amount and is inserted into the u-joints 5mm end which in turn is inserted in the outdrive on the 4mm end..........................now im getting lost, Every step is in this thread when I originally mad it twin brushless which was waaaay too much power, so now its the EVX twin titan setup. All the driveline pics and instructions are in there in depth!! http://forums.offshoreelectrics.com/...ing&highlight=
        • Make-a-Wake
          FE Rules!
          • 6057
          #34
          Need two of these: http://www.ebay.com/itm/Traxxas-New-...item5d34478012
          and two of these: http://www.ebay.com/itm/Traxxas-Boat...item20c86fc446
          and two of these: http://www.ebay.com/itm/Aquacraft-Mo...item2572bd1772
          • mudn_1
            • 49
            #35
            thanks, you have been tons of help.... I am getting close to being finished painting....stupid paint, I hate painting because I suck at it...
            I have a clear coat that I think will go well for a marine application though, its called Glisten PC made by POR-15, I have used in numerous engine parts and it stays clear and holds very strong.... If you all don't know its an epoxy 2 part system, I wsas considering using it on the hull to stengthen it a little bit, as well as protect it from scratches, which it does very well...and use another clear on the deck/hatch
            • mudn_1
              • 49
              #36
              paint is close... I'm just trying to let it cure a much as possible before clearcoat....
              updates are:
              I 've ordered so far
              Octura x447 props, conversion shafts, water cooling p-up's, coils, and a couple of stainless water outlets... mainly for clean looks....we are getting close... I'll try and get some teaser pics up this afternoon of the rough paint
              • mudn_1
                • 49
                #37
                Rough paint pics.... still have to wetsand and clearcoat....as well as repaint the rear of the deck, as It peeled for some reason....
                Colors are Lime ICE, and graphite metallic....
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  #38
                  I like it!!! Great color combo, keep up the good work!
                  • mudn_1
                    • 49
                    #39
                    Yeah, but I absolutely hate painting.... it doesnt matter what I do, or how much time I take, it never comes out as good as I expect...
                    • Jersey Crewmax
                      • 495
                      #40
                      I agree with Wake, looks good.
                      • mudn_1
                        • 49
                        #41
                        got some parts.... first order...
                        • mudn_1
                          • 49
                          #42
                          2nd order.... still working on the install..... I busted a steering boot, I hope the villain ex ones are the same OD.....
                          conversion shafts....
                          cut and balanced X447's....
                          stainless Water outlets
                          • Make-a-Wake
                            FE Rules!
                            • 6057
                            #43
                            Whoa! Got aload of stuff in...................I'll be watchin!!
                            • mudn_1
                              • 49
                              #44
                              Sooo.....while installing the water outlets..... some damn loc-tite attacked the plastic, cracked and pulled it through... luckily only through the hatch area, not the hull.... so I plasti-welded a a peice of styrene over the hole.... I'll re drill and re-install when the new outlet gets here... but thats about all I lack.. I'll get some pics up soon
                              • mudn_1
                                • 49
                                #45
                                new water outlet should be here tomorrow, I just ordered a couple new 3s 5000 lipos.... basically I just have to finish the steering up, mount the esc's and motors... and mount the props.. then tie everything together....
                                then I'll be ready to do some bath testing and hopefully if she floats... then we'll head to a lake somewhere
