nebie brushless question
  • crazzy maxx
    • Dec 2007
    • 498
    hey
    i need to know if a bj esc or a sv esc can handel a ammo 2300kv brushless motor.
    im a newb to brushless
    snort pixi sticks=symptoms-:
  • crazzy maxx
    • Dec 2007
    • 498
    some one has to know
    • Doug Smock
      • 5264
      What voltage, cells?
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • H&MWill
        • 623
        What hull? What prop? Need more setup info.
        Many issues!!!
        • Doug Smock
          • 5264
          some one has to know LOL Hey Will!
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • crazzy maxx
            • Dec 2007
            • 498
            BJ 26 BRUSHLESS. AND AS FOR A PROP I DONT KNOW YET...
            • crazzy maxx
              • Dec 2007
              • 498
              As For Batterys Im Gona Use From Gp3300's To Intellects 4200's On 6 Or 7 Cells...
              • H&MWill
                • 623
                I hear ya brother.
                Prop will play a huge factor so you will need to know. Also what batteries and how many?
                Many issues!!!
                • H&MWill
                  • 623
                  6 or 7 in series to equal 12 or 14 or just 6 or 7?
                  Many issues!!!
                  • crazzy maxx
                    • Dec 2007
                    • 498
                    Im Gona Run 12 Cells
                    • H&MWill
                      • 623
                      I may be mistaken but I think minimum input voltage is 14.8 volts. I could be wrong but I think thats right.
                      Many issues!!!
                      • crazzy maxx
                        • Dec 2007
                        • 498
                        12 Cells Wont Put In 14.8 Volts.
                        • crazzy maxx
                          • Dec 2007
                          • 498
                          prop is gona be a shapened and balanced M435/3 blade
                          • H&MWill
                            • 623
                            You will probably be fine with that. Probably coulld go bigger. here are the specs OSE lists.
                            Motor Diameter: 1.42" (36mm)
                            Motor Length: 1.97" (50mm)
                            Shaft Diameter: 0.197" (5mm)
                            Shaft Length: 0.591" (15mm)
                            kV Rating: 2300 rpm/volt
                            Weight: 8.6oz (243g)
                            Input Voltage: 14.8-18.5V
                            Max. Constant Current: 60A
                            Max. Surge Current: 100A
                            No Load Current: 2.0A
                            Many issues!!!
                            • crazzy maxx
                              • Dec 2007
                              • 498
                              will the stock black jack 26 brushless esc work with it?
