What am i doing wrong here?
  • dana
    • Mar 2010
    • 3660
    mean machine hull leopard 4082 1800kv, seaking 180 v3, m545 strut 1/4 above sponson, 5s2p 4400mah battery 8mm bullets on motor, 8mm and 5mm bullets battery connections .150 cable 3/16 shaft speedmaster hardware. 11.25 timing… i know this is not right…. its a 3.5 d wind. after this run the batteries were warm, esc was a bit hot, and the motor was blazing! ive tried some different timings with different results, mainly cause i dont time my runs and take temps (dont yell at me) , my question is, should i be at 0 degrees timing? is my prop too big? any help thanks. video http://youtu.be/2194Dsd4Aok
    Carl and Ben both guided me toward the 3-5 degree timing on D wynds.Other than that it seems to run smooth.I haven't had a day to experiment as to what effect timing will do(more torque?). BTW nice spot to run there.
    • dana
      • Mar 2010
      • 3660
      thanks man! i have tried 3, and it felt kinda sluggish… i dunno ill give it another shot. any thoughts on 0?
        Not sure,my D's are hooked up to Swordy's so...you know Timming|: low,med,high.Currently all the other motors that are running are 1y
        • dana
          • Mar 2010
          • 3660
          hmm… well to be honest, its never had a run where it has stayed cool. ive tried 3, 7, 11 degrees, and it always get pretty warm.
          • carlcisneros
            • Jan 2010
            • 1237
            set the timing to 3 deg. to start with and if you have an x-442 or x-640 try those first.
            remember to start small and work your way up.
            also run for one (1) minute then take a temp reading.
            • dana
              • Mar 2010
              • 3660
              i have x640, my x442 is currently at the bottom of the lake. i figured i was safe because i ran m445 on leo 4074 2200kv on 4s2p in this thing all last year, with less heat issues
              • carlcisneros
                • Jan 2010
                • 1237
                run the timing at 3 deg then and you should be ok.
                the D winds do NOT LIKE med on up timing.
                they are low timing motors.
                • dana
                  • Mar 2010
                  • 3660
                  i will certainly go back to 3, and try timing my run.
                  • carlcisneros
                    • Jan 2010
                    • 1237
                    sounds good Dana.
                    just take baby steps if you will and you will be rewarded very well with a great running boat
                    and very reliable.
                    • dana
                      • Mar 2010
                      • 3660
                      Thanks man..
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        Yeah, but you're going up to a 5 pitch and keeping the same diameter..............thats alot of prop. The m545 has the same total pitch as an x448!! Just try not to max it all out and have a solid boat, maybe run the 3 degrees and the m445.
                        • Chuck E Cheese
                          • 2136
                          i agree, m545 is alot of prop for that set-up..... i never have used leo motors, but neu 1515 on my outboard pulls a m445
                          see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
                          • runzwithsizorz
                            • Jan 2009
                            • 901
                            Gee, Thankz Carl! Just got my Leo 4092 from Steven to go in my Titan33, with a Sword Fish, and was about to ask this.
                            • dana
                              • Mar 2010
                              • 3660
                              Ok thanks guys, I was looking for more speed but perhaps m447 would have been a better choice. For now I'll go back to my 445 and timing change back to 3 and do a 3 minute run, see how it does
