Hi Iam interested in getting one of the system, and do not know what I need.I want to record the amp draw and motor tempetures. Iam currently running a P lt Sport Hydro. Should I by the 100 amp or the 150 amp system? I could use any suggestion.Where is a good place to by. Chris
Eagle tree recorder
Tags: None
Id go with the 150 amp and a motor temp sensor. Lots of places u can buy from. Search the net and see who has the best price at the moment.
Buy them from right here at the OSE store. Great customer service and you KNOW if you have a problem there will be something done about it.
Get the 150, I'd suggest maybe an rpm sensor as well, about all you really need for a boat. Next purchase for mine will be the GPS.
I also have the little display so I don't have to connect to a computer after a run to check the data.If my boats upside down then who owns the one I thought I was driving the last two laps?
I've been running the 150 amp for a few years now. Best little tool I have for setting up my boats. The brushless rpm sensor is very helpfully also. The LCD display is a nice add on if you want to know maximum values if you dont have a laptop with you.
I Wouldnt recomend the 100amp for boats due to the high amp draw.
I have the 150amp, gps, and lcd screen (so you can see it all in the field). I also have a couple of temp sensor's, but i quit using them, just use a handheld temp sensor at the end of the run. The 150amp has been used to handle up to about 180amp peak pull before with no issues. Mine is 3 years old now.
Thanks for the help. When the store is up and opperating again I will be purching one of the 150 amps units. chris
