Eagle tree recorder
  • chris reed
    • Nov 2011
    • 15
    Eagle tree recorder
    Hi Iam interested in getting one of the system, and do not know what I need.I want to record the amp draw and motor tempetures. Iam currently running a P lt Sport Hydro. Should I by the 100 amp or the 150 amp system? I could use any suggestion.Where is a good place to by. Chris
  • TheShaughnessy
    • 1461
    Id go with the 150 amp and a motor temp sensor. Lots of places u can buy from. Search the net and see who has the best price at the moment.
    • siberianhusky
      • Dec 2009
      • 2206
      Buy them from right here at the OSE store. Great customer service and you KNOW if you have a problem there will be something done about it.
      Get the 150, I'd suggest maybe an rpm sensor as well, about all you really need for a boat. Next purchase for mine will be the GPS.
      I also have the little display so I don't have to connect to a computer after a run to check the data.
      • ksm2001
        • 397
        I've been running the 150 amp for a few years now. Best little tool I have for setting up my boats. The brushless rpm sensor is very helpfully also. The LCD display is a nice add on if you want to know maximum values if you dont have a laptop with you.
        I Wouldnt recomend the 100amp for boats due to the high amp draw.
        DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
        • electric
          • 1973
          I have the 150amp, gps, and lcd screen (so you can see it all in the field). I also have a couple of temp sensor's, but i quit using them, just use a handheld temp sensor at the end of the run. The 150amp has been used to handle up to about 180amp peak pull before with no issues. Mine is 3 years old now.
          • chris reed
            • Nov 2011
            • 15
            Thanks for the help. When the store is up and opperating again I will be purching one of the 150 amps units. chris
            • Bullwink
              • Oct 2011
              • 287
              Can you use the V3 accessories like the GPS etc sold here on OSE with the newer V4 150amp Eagle Tree?
              • sigelitest
                • Jul 2011
                • 422
                anyone have the link on setting this up for 300a. how do you cal after the rewire?
                • jcald2000
                  • 786
                  Do a search here on OSE and RC groups, I posted in both places. The adjustment after the rewire is done in the E/T software. I should have kept a copy.
