is this Aeromarine SprintCat 36???? need advice on motor and prop
  • aminoacid
    • Nov 2011
    • 125
    Hi guys I got this cat and not sure but I think its an aeromarine sprintcat 36?? can anybody confirm? measures about 35 inches or so from sponsoon tip to transom. Its a nitro for sure though.
    Can anybody recommend a low budget motor and prop for this?
    pics are posted.
    boat is 14 inches wide. 35 long and weighs 7 lbs 5oz.
  • Serpents811
    • Oct 2011
    • 381
    pics are posted.
    usually aeromarine hulls got their label inside , as far as motor goes , are you running twin or single , if twin dual 3674 2200kv 4s2p or a single 4074 1400kv 6s2p
    • aminoacid
      • Nov 2011
      • 125
      Single motor for sure
      • Serpents811
        • Oct 2011
        • 381
        leopard 4074 1400kv on 6s and let her rip
        • aminoacid
          • Nov 2011
          • 125
          What about prop?
          • Serpents811
            • Oct 2011
            • 381
            What about prop?
            maybe m445 or x447 and check your temps
            • aminoacid
              • Nov 2011
              • 125
              another quesion perhaps you can shed some light, how can i convert the motor mount from this nitro to brushless?
              • Serpents811
                • Oct 2011
                • 381
                you are going to do some handy work on that one , you are going to need either everything off the hull or work around it
                • aminoacid
                  • Nov 2011
                  • 125
                  how does this compare to the leopard? considering its half the price?
                  TURNIGY 4074
                  • Serpents811
                    • Oct 2011
                    • 381
                    TURNIGY 4074
                    If you check leapord specs they are rated at 2000watts and the leopard 4074 1400kv could handle I think up to 32volts vs. 22.2 on the turnigy
                    • Rumdog
                      • 6453
                      4074 is waaay too small.
                      • Serpents811
                        • Oct 2011
                        • 381
                        That's what thought more like a 4082 or 4092 range
                          • 7651
                          Is there room for this http://www.offshoreelectrics.com/pro...prod=ose-80600 or you could run one of Punisher's mounts that fit 4" rails.
                          BTW That's a really nice looking boat.
                          • Serpents811
                            • Oct 2011
                            • 381
                            Most deff 4082 1450kv in 6s to keep it mild or 4092 1390 8s+
                            • Rumdog
                              • 6453
                              Williams racing makes inexpensive rail mounts. I'd go at least a 4092 Leopard.
