is this Aeromarine SprintCat 36???? need advice on motor and prop
    Originally posted by Rumdog View Post
    Williams racing makes inexpensive rail mounts. I'd go at least a 4092 Leopard.
    That is a 35" cat.
    • aminoacid
      • Nov 2011
      • 139
      ill have to wait for the 4092 to come instock again. 1390kv.
      Serpentine suggested these props, maybe m445 or x447 and check your temps , anybody agree or disagree?
      • Serpents811
        • Oct 2011
        • 381
        With a motor like a 4092 1390kv you might be able to spin a bigger prop than suggested previuosly
        • NativePaul
          Greased Weasel
          • 2770
          Might be able to, but as always with FE, start with a small prop and work up from there, mine has a 1521/2.5D 1200kv on 8s and use from X438-M646 depending on what I want out of it. 1390kv on 6s is a little lower RPM so you should be in that range assuming that leopards run a little hotter / less efficiently than Neu.
          • aminoacid
            • Nov 2011
            • 139
            Speaking 120 or 180 esc? Let's say 6s2p
            • aminoacid
              • Nov 2011
              • 139
              bump
              180-240 perhaps. how do we choose the correct size esc>?
              • JIM MARCUM
                • Jun 2011
                • 775
                Looks like a Sprint Cat Turbine nitro hull. A leopard 4090 409 2/2Y is rated at 125A, 25V, 4200W, and 1390KV. With 6S2P it would run 30,858 RPM, and with the right prop & setup you should see 60+ MPH.
                I suggest you use an offset rudder or it will handle squirely in the straights due to propwash effecting the strudder. JIM
                JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
                • aminoacid
                  • Nov 2011
                  • 139
                  what about prop suggestions?
                  • JIM MARCUM
                    • Jun 2011
                    • 775
                    No. But, there a a lot of more experienced guys on OSE that can help. Send a PM to Fluid, Rumdog or Properchopper. JIM
                      Here's my build, low 60s but high amp draw. Very reliable: Neu 1527/1Y, Schulze 32-170, 6S2P/4500 FlightPowers, worked over x455. The trim tabs are for SAW racing only.
                      • JIM MARCUM
                        • Jun 2011
                        • 775
                        Cool cat Jay. Questions:
                        1. I don't get why the trim tabs for SAW racing?
                        2. Are you REALLY still using an FM radio, or do you just like long antennas?
                        JIM
                          That photo was taken in early 2008, when I built the cat - still had the 75 mHz radio back then because the Spektrum radio I used for oval racing didn't have the range for the long Legg Lake run-ups. If I told you why we used tabs on SAW cats I'd have to kill you......
                          • LarrysDrifter
                            Big Booty Daddy
                            • 3416
                            I think I might know why you use tabs on SAW cats.....the answer seems obvious, but Ill keep my opinion to myself.
                            • JIM MARCUM
                              • Jun 2011
                              • 775
                              Geez Jay!!! Thats a bit harsh. How about you send me a PM and I'll trim my fingernails instead?
                              And Larry, I've never known you to keep your opinion to yourself before - so what's so "obvious" about tabs on a SAW cat? JIM
                                How about: "if you have to ask then you are unworthy"?
