Rolled my Persuit :(
    • 5554
    Originally posted by rcboatmanwithkids2880 View Post
    That's what I tell my wife !!!! ( lol )
    Another comedian.................!!
    • HOTWATER
      • 2323
      Lol!
      "Will race for cookies!"
      IMPBA D12
      • iamandrew
        • 574
        Just got back from another trip to the lake, went really well, although "everything" was a bit hot inside
        I might sand down the X645 prop a bit more, and give it a test with my 642 and see if it cools itself down a bit.
        • ron1950
          • 3024
          try a stright edge on the bottom past the trim plate....screew the plate to be flatt to the stright edge and that will prob fix the chine walking....it did mine anyway....i run a m445 and have never had a heat issue with mine
          • iamandrew
            • 574
            yeah i wonder if the extra pitch on a X645 is enough to cause the extra heat
            • ron1950
              • 3024
              645 is alot of prop for that esc....strain on the motor will make it get hot
              • keithbradley
                • 3663
                The larger prop you run, the more problems you will have getting it to handle well also.
                I NEVER feel safe with just hatch tape on a mono. On a cat or hydro you can start the tape on the bottom side of the front of the tunnel, which helps hold things on. On a mono, there is no way to tape that is foolproof in a hard crash.
                Check out my hatch bolt kit thread and hatch seal thread in the for sale section. Shipping to Aus is a little pricey so you may not want to spend that much, but it might give you some ideas of what to do to solve the problem.
                www.keithbradleyboats.com
                • drwayne
                  • 2977
                  re mono hatch
                  I now have a locating pin epoxied under the nose of the cowl that slides into a purpose made block at front the hull opening.. and then tape around. Never lost a cowl.. and my DF33 does acrobatics often.. http://www.youtube.com/watch?v=FlCvceR8oQw
                  • iamandrew
                    • 574
                    yeah the persuit allready has a tongue made into the hatch then a hole in the deck for it. Ive now got 2 types of latches so ill give the small ones a go, and if they are too small, ill make sure ive got enoguh space to install the large cowl locks.
                    Just had a few issues on making a 5.5 bullet parallel adapter, surely there is an easier way hahaha
                    maybe i should have done 8MM on the ESC, then id be able to fit the two 12gauge wires in there , aaaaaaah well
                    all for tommorow :)
