Rolled my Persuit :(
  • iamandrew
    • 574
    Well Id finally finished everything and took it down to the lake this afternoon because of about 3 hours of good weather!
    I was at about 3/4 throttle and the boat started like bouncing from left to right, like wobbling, it then went right over and done a tumble, the hatch came off and the hull got water in it. Probably about 2 inches in the bottom, the batteries stayed fairly dry but the receiver got wet.
    Ive just cleaned everything out, put metho through the receiver and the servo looks allright as well.
    The motor wasnt fully submerged either
    One thing, one of the leads came off the motor in the crash, and it blew the positive wire off on the bullet plug, and tore down the heat shrink.
    DOsent apprear to be any other damage to the boat but still awaiting to to full dry out.
    I think the strut is about level, and it seemed like the batteries were in an ok spot because it didnt porpoise.
    Ive just screwed down the trim tabs at the back, so they are about 2mm above on the hull (not flush), and then they go slightly down.
    I think ill install some hatch locks in it , because the tape did NOoffing!!!
    Does anyone else have any tips for this hull? it seemed like it was going great, it could have just been me with too much throttle though!
  • jamespl
    • 742
    If you tape the hatch fully it shouldn't come off. I had a flip with my genesis and it landed hatch side down in the water but it was fine inside once it drifted back in. I tend to go through patches where I flip the boat, then break something like the rudder.
    • iamandrew
      • 574
      Yeah well im not sure if i should install the spare hatch locks in the rear of the hatch, or if i should just do two runs of tape slightly side by side around the entire hatch. the front has the lip that slides into the hull, but its not exactly a locked in bit
      • pyroM!KE
        • Jan 2011
        • 375
        If its cold out, keep your tape on the dash with the heater on to help keep the tape warm..It will stick better when its warm..
        • iamandrew
          • 574
          well its "Summer" here in australia at the moment, but its only been about 25 to 30 degrees instead of the usual 40 hahaha!
          Ive dryed the electronics, cleaned with metho, WD40 on the connectors, plugged it in, and so far, everything worsks! servo is allright, same with the receiver which was water logged.
          I used Metho and a tooth brush on the receiver and it cleard all the tiny bits of corrosion from it, seems all new again! I might do the double tape next time and see how it goes.
          Does anyone else get the death wobbles? hahah
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3278
            I always wipe my hulks with a clean paper towel using brake clean before I run. Tape always holds, unless the crash is bad.
            • Rumdog
              • 6453
              I dont usually wipe my hulk. You won't like him when he's ANGRY!
                • 5554
                Here's what i did to my Pursuit after a similar crash..............canopy hasnt budged on flips ever since.
                  • 5554
                  Just got that!! Great stuff!!!!!
                  • iamandrew
                    • 574
                    hmm yeah that looks like a good solution. Definatly better than the hatch locks.
                    I run in salt water here and id would be better to have a hatch which isnt going to move, Ever !
                    • pyroM!KE
                      • Jan 2011
                      • 375
                      Have a good look on here about getting rid of the wobbles.. http://www.fastelectrics.net/
                      My Cyber Storm 33 is the same boat as yours (actually the persuit is a CS clone)..Im getting a little over 60mph and its very stable..Just take your time trimming her out..
                        • 4297
                        Yes I had that with my 36"Shockwave mod to fe,
                        It a lot better now.
                        All my boat have neoprene hatch seals and locks, No tape any more.
                        Makes it a lot easier to check gps and stuff.
                        Hear in post #8 I did my mini hydro bolt with a seal and one nut on top,http://forums.offshoreelectrics.com/...-my-Small-Bolt
                        http://forums.offshoreelectrics.com/...ar-Hatch-locks
                        • LarrysDrifter
                          Big Booty Daddy
                          • May 2010
                          • 3278
                          Stupid phone!!!! Smartas$!!
                            • 5554
                            C'mon now, that was funny....................
                            • rcboatmanwithkids2880
                              • 340
                              That's what I tell my wife !!!! ( lol )
                              Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
