HK 5682 1700kv Pro Competition
  • Mel279
    • Dec 2008
    • 873
    Originally posted by iamandrew View Post
    Hi there
    ive got the motor, i was going to install it into my MMP Rapide but i think it might be overkill, it with its mount its pushing 800grams.
    I was going to run it on 5S with a T180 in that hull, but not sure now!
    how big is your boat?
    • iamandrew
      • 576
      its 95CM long but its verrry narrow! its about the same width of a persuit. thers not that much room if i install it in the wrong spot
      • Mel279
        • Dec 2008
        • 873
        I think you can run with that setup and it will run well but a bit heavy due to the motor weight. I even tried running leo 5692 730kv with 12s 5000mah in my 32" DF cyberstorm, its really heavy but it run quiet nicely.
        • iamandrew
          • 576
          Shoving mine into an Osprey hull this weekend hopefully
          will give it a try with 5S 2P and see if it works
            • 9481
            please keep us posted bro!
            • iamandrew
              • 576
              yeah i dont know now,
              Everyone else ive read up on here is using like 6S + and a 50mm prop, but on a 1300KV 5692 or something like that
              i was just going to use the 1700KV with a T180, and a X645 prop and see if it works
              • jkr
                FE Addiction
                • 582
                In your case i would go for a 4082 1600kv or 4092 1730kv if you run a x645.
                A friend makes an outlaw with 5682 1700kv and 52mm prop with sf 240.
                • iamandrew
                  • 576
                  ah i mean ive allready got those parts though!
                  Also got a lot of 8MM bullets as well.
                  I personally think that the T180 should be fine, i know a lot of people run the 240s ESCs , but i cannot even get my wiring connections to hold out past about 100 amps anyway!
                  • jkr
                    FE Addiction
                    • 582
                    Ok.Didn't know.
                    I use 2 pairs of 6mm bullets for high amp as the 8mm is too stif and there is a lot of chance to harm my cables.
                    • JIM MARCUM
                      • Jun 2011
                      • 775
                      DSCN0951.jpgDSCN0952.jpg76621[/ATTACH]
                      Originally posted by jkr View Post
                      Ok.Didn't know.
                      That's why you need to use the 8mm bullet connectors, and a 200+ Amp ESC. I made a soldering jig (pic attached) that makes soldering 8-6mm connectors EZ.
                      But, if you want 6mm bullets instead, I'll trade mine for your 8mm bullets. JIM
                      JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
